Auto shifter rattles
Old Jan 1, 2010 | 11:56 AM
DailyDrive's Avatar
This particular joint has at least 1/8" play in it, and it rattles around while driving. Is there a part # for those plastic insert bushings?
Old Jan 1, 2010 | 12:01 PM
JamesD's Avatar
Take some electrical tape, cut it to width and wrap it around the bushing.
James
Old Jan 1, 2010 | 12:26 PM
DailyDrive's Avatar
I thought duct tape was the tape of choice for those types of solutions.
Old Jan 1, 2010 | 01:14 PM
JamesD's Avatar
This is not a Jeep site
Old Jan 1, 2010 | 01:33 PM
raydouble's Avatar
Can you figure out which one it is from the picture?
http://ipcomet.info/home/adbaa1cd/b6...xMi5o/dG1s/b1/
Get the part number and put in here....
https://www.1sttoyotaparts.com/partscat.html
I tested a few, looks like you will be able to locate it....
Old Jan 1, 2010 | 01:55 PM
DailyDrive's Avatar
Well, I took it apart, and turns out there is no bushing inside. Metal on metal. All the joints in the linkage are worn anyway and wobble. Guess just going to have to accept that on 100K+ miles.
Old Jan 4, 2010 | 11:09 AM
SkidPalace's Avatar
I think there are dozens upon dozens of high mileage Runner and Taco owners on this board that would disagree with that last statement. My cockpit seems tight as a drum with almost 140K.
If there aren't any bushings to replace, maybe packing with some thick lithium grease will quiet them down?
Old Feb 6, 2010 | 07:36 AM
AllmanBrother's Avatar
my auto shift selector also wobbles. anyone know which part number is the correct replacement?
i dont know if your wobble was the same as mine, which was the actual shifter stick that moved side to side. i fixed it, and heres the write up:
https://www.yotatech.com/forums/f2/s.../#post51370809
jb451
7
Oct 7, 2022 06:58 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
eggens
Sep 5, 2015 12:16 AM
kelly1450
Sep 2, 2015 12:29 PM
donovanloj
Aug 16, 2015 10:07 AM
