Auto-off headlamps <3rd Gen>
Old Jan 27, 2004 | 04:38 PM
hungryStu's Avatar
I am curious to know if there is a way I can turn my headlamp "wand' to "on' and after shutting down the truck have it shut off? . . . get in, turn it on and headlamps come on? Seems like it would be doable.
-Stu.
Old Jan 27, 2004 | 04:41 PM
lee's Avatar
lee
should be. mine do it.
Old Jan 27, 2004 | 04:43 PM
hungryStu's Avatar
forgive my ignorance but.. . on the '01, how do you turn your lights on? Is you=r switch the on the turn signal or is it a rotary on the dash? Is yours also eq. w/DRL's?
-Stu.
Old Jan 27, 2004 | 05:51 PM
hungryStu's Avatar
also, what would I replace to get this feature???
-Stu.
Old Jan 27, 2004 | 07:18 PM
lee's Avatar
lee
my headlight switch is on i think the turn signal thing, yes.. cant remember exactly as i just always leave them on and only switch the fog lights on and off during night / day.
Old Jan 27, 2004 | 07:51 PM
Andrey's Avatar
The headlights on my '01 4Runner come on when I turn the engine on. When the engine is off, headlights are off as well. My headlights switch is on the turn signal stalk if that makes a difference. I have DRLs though...
By the way, I have an extra headlights/turn signal switch from 2001 4Runner SR5, so if anyone is interested, let me know!
-- Andrey
Old Jan 27, 2004 | 08:08 PM
arjan's Avatar
My '97 has running lights. There is a DRL relay under the dash and a resistor pack next to the battery. I unplugged mine to disable the DRLs. I think the wiring is quite a bit different because in DRL mode the light get their power through the resistor pack (metal block with cooling fins). When I turn on the lights with the switch, the resistor pack gets bypassed so the light are brighter. This is done by relays under the hood.
I guess you could figure out which relay is the headlight relay and run a relay parallel to that which is turned on by the ignition (engine runs, lights are energized.) If you add the resistor pack you end up with basic DRLs.
If you're interested and this sounds confusing I could draw up a basic schematic, but I would have to look into the wiring a bit more.
Hope I confused the heck out of you
Old Jan 28, 2004 | 04:39 AM
lee's Avatar
lee
yea i have drl's too of course. thing i like most about the set up is that if i park, and turn the engine off, the lights stay on until i open my door to get out.
i dont know why, thats just awesome to me
Old Jan 28, 2004 | 06:54 AM
arjan's Avatar
I see now what you would like. It's not impossible but an easier way would be to use this:
http://oeiwcs.omron.com/webapp/comme...6&prrfnbr=3988
Mount that under the hood set the delay time and wire it into the headlight relay as a "off-delay" timer. If you order one from an electrical supplier make sure to get the matching base.
I personnally use the analog dial version quite often, but I noticed that they don't have a 12vdc version.
Old Jan 28, 2004 | 07:01 AM
Andrey's Avatar
Another option would be to add DEI lights modele, part #545T. This module works only with DEI alarms, but in many cases adding DEI alarm plus DEI lights still will be cheaper than getting DRL module from Toyota.
http://www.caraudio-caralarms.com/545T.html
-- Andrey
Old Jan 28, 2004 | 07:05 AM
lee's Avatar
lee
wait, so even if you turn your wipers on just real quick to get rid of some water that splashed onto your windshield, theyll turn on??
Old Jan 28, 2004 | 07:09 AM
Andrey's Avatar
Don't you have to have engine running or at least have the key in "Run" position for wipers to work? So yeah, the lights will be on at that time.
-- Andrey
Old Jan 28, 2004 | 08:20 AM
bobzemuda's Avatar
I have/had DRLs that I disconnected. My auto on off still works, however.
As in, if I leave my lights on and turn the truck off they go off also. When I turn it back on, they come back on.
Bill
Old Jan 28, 2004 | 10:09 AM
JohnM's Avatar
My 2000 SR5 Sport turns the headlights off automatically when I turn the ignition off. A nice feature I just discovered the other day. Of course, my truck is about 3 features short of being a Limited.
Old Jan 28, 2004 | 10:12 AM
lee's Avatar
lee
ditto, bro
LittleUgly
15
Jan 2, 2020 01:30 PM
Flightguy
Oct 2, 2015 05:34 PM
voiddweller
Oct 2, 2015 07:47 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
charlie_fong
Sep 27, 2015 10:06 PM
