ATS a-arms
Old Dec 7, 2003 | 07:03 AM
  #81
BruceTS's Avatar
Currently they are cranked down as low as they can go. I was supposed to install my OME shocks and springs last weekend, but got busy with other projects. Looks like today is out.... just looked outside and it's raining...... Oh' well...... Yes it's about 2" higher in the front, the rear has stock HD set-up..
I attached a picture to show CV angle....
Old Dec 7, 2003 | 07:13 AM
  #82
ravencr's Avatar
Have you done the diff drop yet? Also, what's the maximum height that TC recommends cranking them up to? Also, with the new fiberglass fenders will 35x12.50's fit now without rubbing?
Chris
Old Dec 7, 2003 | 07:46 AM
  #83
BruceTS's Avatar
Yes I did the diff drop, and I have no plans on running anything larger than 33", due to the fact that the drivetrain can't handle it, but we'll see..... Total Chaos recommended 33" max...... I'm not concerned with rubbing against the fender as much as the inner wheel well.......
Old Dec 7, 2003 | 07:49 AM
  #84
ravencr's Avatar
Well that stinks. I wonder why they recommend nothing larger than 33's? The only place I rub is the frame, but I'm sure these a-arms would fix them. But, I've also done some major fender pounding/trimming. There are people running 35's with the stock rear axle, but I'm not sure if anyone's running 35's with the stock or modified a-arms.
Chris
Old Dec 7, 2003 | 07:56 AM
  #85
BruceTS's Avatar
You can run 35", but the 7.5" diff is what I'd worry about more that the rubbing issue. The IFS driveline ain't that strong. I've seen plenty that have 35's....
Old Dec 7, 2003 | 08:16 AM
  #86
nice rig Bruce
I cant wait to see it!
It look's like you have a lot of stuff that i have too. what part of so cal are you from ? Im from s.d. or Escondido 92025.
we need to hook up and wheel! I got a new dirt bike so i have been riding more then wheeling. I need to blow the dust off the rig and go before there is too much snow up in big bear. We also go to the hammers,los coyotes,borrago,oct wells,Rubicon,moab and some day maybe Martinaz? in AZ (hint hint)
Your rig will do real good! I go fast or slow and it works good. I dont go as fast as some ford rangers in the desert but my rig seats 4! and it works really good up in the rocks too. The only thing i might someday add would be a MC09. I would like to make someone else work the bugs out.(Steve 44runner)
any more crawl than that then i would need a rock buggy.
I might also do a full cage. Thats why i dont Haul the mail in the desert. If it would go over it would sux.
If you need help just ask.
We need to work on getting them fenders painted !
Fear
Old Dec 7, 2003 | 08:33 AM
  #87
ravencr's Avatar
Fear, what did you do in the rear?
Chris
P.S. Do either one of you have a web site whre we can look at your rigs?
Old Dec 7, 2003 | 08:36 AM
  #88
I use cust made coils and new lower arms with heims. moved the rear shocks to run a 10 inch 6100 billy.
Fearweb page
oops fixed it
Old Dec 7, 2003 | 08:50 AM
  #89
ravencr's Avatar
What's your total travel in the rear now? How much more than a OME setup is it? Any gas tank trouble?
Chris
Old Dec 7, 2003 | 08:51 AM
  #90
44Runner's Avatar
Originally posted by sschaefer3
After spending a day with Fear4Runner, his long travel was impressive in Southern California, but I wonder how it will do in Arizona, where all the trails are tight and slow.
Another thing that really bothers me about all this long travel stuff is that although you gain IFS travel, you still have the small 7.5" front diff and weaker style axle shafts.
The reason I would invest in the front end would be to gain strength. Be that a Toy solid axle or a Dana 44.
Come on Steve. You have "invested" more in the front end than anyone on this board. This is also the second time I have seen you hint that you might be considering a SAS. Just do it, what are you afraid of aside from sick travel and stronger components? Sure you have stated in the past that you would never do it, but you contradict yourself all the time, we are used to it by now. Quit beating around the bush and fire up the torch...
Old Dec 7, 2003 | 08:53 AM
  #91
44Runner's Avatar
I didn't have any "bugs." You have any bugs Steve?
Old Dec 7, 2003 | 08:54 AM
  #92
ravencr's Avatar
I don't know what you guys think, but I think his wife has capped his spending, and has forced him to mod up her vehicle now!!
Chris
Old Dec 7, 2003 | 09:04 AM
  #93
steve had a bug at Oct wells. He got there and had to pull the shifter boots off to see why it wouldnt going low or he was getting some noise or something like that. or he just wanted to show it off! lol mmmm droool lol
44 do you have a V6 auto? I dont think it will work on my rig (v6 auto is too long?)
Old Dec 7, 2003 | 09:09 AM
  #94
ravencr here is some
rear flex
Old Dec 7, 2003 | 09:18 AM
  #95
BruceTS's Avatar
When I was on the phone with Marlin's shop, they said it would be no problem putting the MC09 in the 3.4L with auto or stick.
I still need to do some fitting before I can get the fenders painted, once my front bumper shows up, I'll have to take it apart. My powder coater is gonna color match it to my ride, I like the Sahara bumper, but not the chrome hoop......
Old Dec 7, 2003 | 10:39 AM
  #96
44Runner's Avatar
Sounds like a simple t-case problem that has nothing to do with his particular setup. Old yota t-cases are just about as simple as they come. There is not much that can go wrong short of bearings or major breakage. My works like a charm, 1st time, everytime...
I have a 5sp. The MC09 fits the autos too. I believe the manual and auto are the same length from bellhousing to t-case. The manual in my truck is the longest freakin manual I have ever laid eyes on. I think there must be a bunch of dead space there so they could make it the same length so they wouldn't have to change much between the too trucks...
Old Dec 7, 2003 | 12:30 PM
  #97
ravencr's Avatar
rear flex
That's some pretty sick flex, and I'm checking a couple shots of mine to see the difference. I'll post a couple of mine so we can see the difference, and I'm pretty sure yours is better.
Chris
Old Dec 7, 2003 | 12:36 PM
  #98
thanks if you look the wheel is about as high as the top of the rear bumper.
the rear of our rigs flex really good.
Fear
  #99
ravencr's Avatar
I don't know if I ever told you but I'm doing a similar rear bumper setup as you have, but here's some pics of similar flex shots of mine with OME's in the rear:
Chris
P.S. I have some more somewhere, but I've got to find them.
Old Dec 8, 2003 | 05:34 PM
  #100
RobT2k's Avatar
How about these?
