Ashtray CB Mod - Pix
Old Mar 28, 2006 | 01:15 PM
BajaRunner's Avatar
Okay, I got my CB mounted into my ashtray. Im pretty happy with the results.
No matter what I tried, I couldn't get the thing perfectly to sit flush, but, its close enough for me.
I ran the pos wire directly to the battery, as from my research was the very best way to get a clear signal, with the least amount of noise. It was stated over and over how important it is to run the pos wire of any 2-way radio to the source.
I had to take out my entire console area, unplug some wires and cut out the ashtray backing. Ran the wires through the back, and grounded my neg wire to the sheet metal under the center console plastic area. The CB actually was pretty tight in the area where I mounted it, and just used some double stick tape on the top to make it really sturdy just in case.
So, with these new CB's, do you not get that usual static sounding crap when the squelch is turned all the way down? I enjoyed listening to the rednecks from god knows where. Now, I can't... I can only hear clear transmissions within range. Which I guess is nice. My buddy isint around to test the range on it yet.
Here are the pictures.
Old Mar 28, 2006 | 01:18 PM
Bob_98SR5's Avatar
did you get it tuned? best way to find out rather than transmitting/receiving with a friend
bob
Old Mar 28, 2006 | 03:20 PM
BajaRunner's Avatar
Nope, I haven't gotten my antenna tuned.
I haven't found a place to get it done. I guess I could stop by radio shack and check out their meters, but, I'll only use it one time
I went and drove around for a bit, and I was picking up a lot of stuff. Its great. I am super stoked!
Old Mar 28, 2006 | 03:23 PM
fireteacher's Avatar
30 return policy!!! open it carefully...did i say i was froogle!!!!
Old Mar 28, 2006 | 03:57 PM
BajaRunner's Avatar
hmmmm... now you got me thinking ;D
Old Mar 28, 2006 | 04:15 PM
FUZION's Avatar
Old Mar 28, 2006 | 05:58 PM
not to jack thread but i was at walmart years ago and a lady was returning a pair of white keds, now brown, cause they "didnt last long" and to my amazement, they returned them...thus the light bulb went on!! anyways use a blade and open the back of any packages that are a one time use type deal!
Old Mar 28, 2006 | 05:59 PM
awesome install by the way
Old May 23, 2006 | 10:26 PM
Spanky's Avatar
nice install, but you are wanting it to maybe be more "flush" ?? Could it be from the connection from the antenna coax not letting you push it all the way back? I had this problem in my truck so i bought a 90' angle adapter and was able to get about a 1/2" more room to work with! So if thats your deal give that a try.
As for getting your antenna tuned.... it cant be stressed enough!! (ha ha just like fireteacher put it... 30 day return policy!! thats funny stuff!!) but anyways, you could actually damage your radio if you are using it with high SWR's !! get a meter and get them as low as possible, like 1.5 or less is really good!
by the way i am curious, what kinda antenna are you using?
Old May 24, 2006 | 07:52 AM
BajaRunner's Avatar
Yeah, I already have the 90* connector... Since the install I've been able to push it back in a little more. The pictures make it look like it sticks out, but, it really doesnt.
I got a SWR tuner and tuned it myself. Ch 1-30 are under 1.5 while 31-40 are about 1.7.
Im using a firestik II antenna.
Old May 24, 2006 | 08:21 AM
OutdoorLiving's Avatar
Sweet install!
Old May 24, 2006 | 06:50 PM
norflaballer's Avatar
thats big pimpin...
but if i did that... where woudl i put my change from burger king? haha.
that is sooo clean though. i like it.
Old May 24, 2006 | 08:37 PM
Spanky's Avatar
that is a good point by norflaballer!! where would I put all my stupid change at?? haha I did consider this very same intall in my change/ashtray holder but i liked the under my cd player mount. Well you have done everything by the book I think. Clean install and got the antenna tuned well, but if you really want to get the most outta your cb gimme a private msg and i will let ya know what route you should go. but if its just for the trail and maybe around town, then youre more than fine i imagine!
Old May 25, 2006 | 06:39 AM
99SR5's Avatar
cool have you had any problems with electronics because i was reading in the manual it said CB's can screw stuff up
Old May 25, 2006 | 07:40 AM
BajaRunner's Avatar
Its been about 2 months since the install, and there have been no electrical problems... Are you talking about speakers or something? I've never heard of that before.
Old May 25, 2006 | 10:37 AM
99SR5's Avatar
im not sure i just read it in my owners manual
Old May 25, 2006 | 09:11 PM
Spanky's Avatar
99SR5:
your owners manual talks about cb's ??
Old May 30, 2006 | 07:20 AM
99SR5's Avatar
yeah im pretty sure, its been a while since i looked at it
Old May 30, 2006 | 01:28 PM
i tried this mount as i was inspired when i saw it. i have the factory amp back there and did not like how far it made it stick out. anyhow, sweet install again...i used velcro and mounted it under the ignition!!! works perfect for me!!!!
(plus i get my change holder back!!!
Old May 30, 2006 | 01:36 PM
TexJJ's Avatar
What mount is that fireteacher?
