anyone pictures: 2 inch body lift on stock tires
Old Apr 24, 2006 | 05:50 PM
FUZION's Avatar
Im debating on a 1" 1.5" or 2" body lift
i know what the 1" will look like
but I cant find many of the 1.5 or 2 on stock tires.
any out there besides this one
2" roofgoof
Old Apr 24, 2006 | 06:47 PM
ebelen1's Avatar
Just my opinion but you will not want more than 1" body lift w/ your spacer lift on stock sized tires...
It will look funny.
Old Apr 24, 2006 | 07:11 PM
FUZION's Avatar
Thats what I was thinking at first but then I saw roofgoof's and it looked okay. thats why I wanted to see some more.
Old Apr 24, 2006 | 07:24 PM
ROOFGOOF's Avatar
Check out the profile link below and see my first few posts for a few more pictures of 2inch BL. If I have more I will post them for ya. I also have pictures of my OME / BL lift with stock tires on that thread... I didn't think it looked too bad... the Limited fender flares stuck out a bit with my stock wheels though.
Good luck.
https://www.yotatech.com/forums/f79/roofgoofs-1999-4runner-71997/
Old Apr 25, 2006 | 06:40 PM
FUZION's Avatar
It will look funny.
The spacer lift was only to lift the rear. I didnt go 2 inches all around.
arent you runnin stock tires with a ~2 inch lift.
i was kind of leaning towards the 1.5 in lift
It's either get the lift and loose the guard or forget the lift and keep the guard
or get the lift, ditch the guard, get the pp spoiler
ah so many choices
Old Apr 25, 2006 | 06:49 PM
JHupp's Avatar
I think ebeln has 265/75/16s, which should be comparable to the 32" tires you have. My 265/75/16s were almsot 32" exactly when new, and I run a 3" suspension lift all around. IMO opinion, I would just go with a spacer lift on your front suspension. If you do a .75" Daystar they just sit above the strut tower. There is no need to take the whole coil out. It is fairly easy to do, and there might even be larger spacers out there, you could use 2 of Bamachem's 1/2". With the body lift you would probably lose the brush guard, which kinda sucks. Just a thought, my buddy Robby was able to keep his WAAG with a 2" body lift, he just re drilled the holes lower on the bracket, but he has a 98 Taco, on mine it looks like I could keep my WAAG too with a 1" BL. Just some fod for though. 2" should look just about right, if those are 17x8s, all the better. I think mine looked a lot better when I changed to 16x8 rims.
Old Apr 25, 2006 | 07:42 PM
ebelen1's Avatar
ah so many choices
I thought you were going w/ a combo lift of suspension and body lift. If not, then disregard my comment. I do have 32s w/ about 2 1/2" of lift but will probably throw on some 285 AT's when the 32's wear out. It will take awhile for this to happen as two of my tires are pretty new and at least 60% on the other two.
Old Apr 25, 2006 | 07:47 PM
slick858's Avatar
jason said it, I SAID IT!
2" BL George!!! NO MORE NO LESS! it will look GOOOOD!
Plus it will be bigger, thats always a hit with the ladies...
Old Apr 25, 2006 | 08:11 PM
FUZION's Avatar
Jeremy sent me some pics of his 2in and i think im convinced
but then again i think im stupid for lifting my 2wd anymore
Old Apr 27, 2006 | 11:04 PM
grimpy's Avatar
I might go back to stock 31" tires with my 4.5" lift... If I do, I'll take some pics to show you how it looks....
Old Apr 27, 2006 | 11:10 PM
HUTCHSTACO's Avatar
why would you want to go back, ur truck looks good
Old Apr 27, 2006 | 11:39 PM
BajaRunner's Avatar
Id rather buy and drive a ˟˟˟˟˟˟˟ 82 Tercel on skateboard wheels than drive around my truck with it costing $65 to fill up my f$5'n tank.
Old Apr 27, 2006 | 11:56 PM
grimpy's Avatar
Gas is killer and I drive alot... Hell it cost me $12 a day to drive to and from school... I get 13 mpg currently also.
Old Apr 28, 2006 | 06:26 AM
ebelen1's Avatar
Say it isn't so...
Old May 1, 2006 | 06:41 AM
JHupp's Avatar
Wow dude, I like your truck a lot, but am feeling you on the gas prices. Before I had mine lifted I urked on here for a while, and I remember looking at your truck, same color, same rims. 31" tire might look wierd with 4.5" of lift, I'd probaby take out the body lift and sell it to me. just a though.
Jun 1, 2021 01:51 PM
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
Yotoder865
Jul 9, 2015 07:51 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
