Anyone install polyurethane steering rack bushings on a 3rd Gen?
Old Apr 1, 2003 | 02:08 PM
TDiddy's Avatar
I just received some coil spring isolators and a steering rack bushing set from Northwest Off-Road. I was going through the parts and list for the steering rack kit, and found that I have an extra sleeve. This 3rd sleeve, which is not listed on the parts list, is different in length from the two that are supposed to be in there.
Anyone else have this happen? I haven't called NWOR or Energy Suspension yet, but I probably will.
Old Apr 1, 2003 | 02:19 PM
TDiddy's Avatar
Well I just called Energy Suspension. They said that happens from time to time...an occasional extra piece gets thrown in.
So much for QC, haha.
Old Apr 1, 2003 | 03:45 PM
boss hog's Avatar
that center metal sleeve for the middle mounting bolts, the inside diameter may be to small, i had to drill out a little of the inside sleeve be fore center center mounting would go thru it, i found out the hard way, test fit the center bolt thru the metal sleeve frist. you may want to use oringinal center bushing and sleeve, if you do install kit, your streeing will tigther, no play at all, at the same time you will feel more of the road thru the wheel. :pig:
Old Apr 1, 2003 | 03:58 PM
Firefyter-Emt's Avatar
Hey, at least they got back to you.. They blew me off when I complained about supplying upper control arm bushing sleeves but not the lowers...
Old Apr 1, 2003 | 04:09 PM
TDiddy's Avatar
Boss hog, thanks for the tip, I'll definitely test-fit it first.
Firefyter, I guess it could have been worse; I could have been short parts instead of having an extra. Luckily when I called I got someone live, so I didn't have to wait for a return call or anything. That's too bad they blew you off like that.
Old Apr 1, 2003 | 04:18 PM
FattyCBR's Avatar
Hey Tom can you post pics of the install? I'm kinda curious about this myself since it's such a cheap upgrade.
Thanks
Old Apr 1, 2003 | 04:22 PM
TDiddy's Avatar
Sure. I'm not sure if I'll get to it this weekend, it will depend on how the OME's go I guess. But when I do, I'll take pics.
Its funny, I didn't order them because I really needed them, but because NWOR said they have a $25 minimum order. The coil isolators are only around $15, so I needed something else.
Dr. Zhivago's Avatar
Away
Ditto.
It's a great mod.
My .02
Dr. Z
Old Apr 1, 2003 | 04:26 PM
BTW.. I will say from what I have played with, I do think the kit will be nice when done.. I just think it is a little shoddy to tell you to basilcy burn the old rubber bushings apart to scavange the old stuff from them...
I guess I am biased because mine were rusted all to hell and I have to make a 150+ mile round trip to pick up a set of lower control arms to get the sleves from.. But the pain, is that they give you the sleeves for the rear bushings...
Old Apr 1, 2003 | 04:35 PM
FattyCBR's Avatar
Well, based upon JD Hog's and Dr. Z's recommendations I may just be ordering up some of these bushing.
Good luck with the install Tom.
Old Apr 1, 2003 | 05:01 PM
sschaefer3's Avatar
I have the poly as well. So does Gadget.
glowz825
Jan 25, 2022 09:28 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
HaydenConQueso
Jul 12, 2015 05:22 PM
