Anyone done this?...Increased approach angle!
Old Aug 11, 2003 | 08:04 AM
ravencr's Avatar
I'm going to have a guy make a bottom bumper that will fully cover the tranny cooler and radiator, in addition to making a nice place for two lights to be mounted on too. It will be constructed out of tubing that's 1/4" thick and bent around to sort of look like a bull bar, I guess, like they put a lot on the superduty fords that I've seen here lately. My goal is to make it as small possible, both guarding the undercarriage, not decreasing the approach angle, and a nice place to mount some additional lights on the top.
That's the goal, and yes it will be very strong too.
Chris
Old Aug 11, 2003 | 10:26 AM
Gadget's Avatar
Originally posted by sschaefer3
You make me laugh so hard. They are both mass produced one in a million knock offs.
They both suck. They are both sheet metal. Make one out of good old American plate steel if you want to whip it out and see how big it is.
My bic lighter is bigger than your cricket lighter.
Sometime you just demonstrate just how odd you are...
OK, so I guess I should of said, the ARB is MASS produced better then the TJM is MASS produced out of sheet steel.
Gadget
www.GadgetOnline.com
Old Aug 11, 2003 | 10:29 AM
Gadget's Avatar
Originally posted by ravencr
I decided to take the front valence off today, because I think I have a pretty good idea of what I want to do on the front bumper that will look good and be functional too. Here's a close up shot of it removed.
Chris
For those of you that are confused about the difference between a stacked plate aux tranny cooler and a tube-in-fin cooler, the link here shows a tube-n-fin type. They are much more restrictive then the stacked plate type and that is why the stacked plate is much better to use.
You can go over to my site and see what a stacked plate cooler looks like.
Gadget
Old Aug 11, 2003 | 10:45 AM
ravencr's Avatar
Thanks for pointing out that I obviously bought junk. What's the best one then, Gadget?
Chris
Old Aug 11, 2003 | 11:04 AM
  #25
TDiddy's Avatar
Most people go with a stacked plate cooler from Hayden (model is Transaver Plus).
I ordered mine from Makco Distributing.
Old Aug 11, 2003 | 11:05 AM
  #26
Gadget's Avatar
It is not junk so do not think that. It is just the other type, stacked plate, is preferred as it has more surface area for heat exchange and less resistance to flow so more fluid can flow through it and get back to the pan.
There is so much confusion between the two types and your picture is an excellent example of the tube-n-fin type. If it is alright with you I would like to put it on my site so people can see the difference and understand what I am talking about.
Gadget
Old Aug 11, 2003 | 11:06 AM
  #27
Bob_98SR5's Avatar
You make me laugh so hard...
Jeez Schaef, easy, easy! There are definitely better ways to say what you just said, my friend.
Bob
Old Aug 11, 2003 | 11:20 AM
  #28
ravencr's Avatar
No problem at all Gadget! Thanks for the explanation, and I may change to the better one someday.
Chris
Old Aug 12, 2003 | 06:15 PM
  #29
ravencr's Avatar
Well, I went to the fab shop today to find out what I was looking at on the front bumper I had in mind, and I've decided that a buddy of mine and me are going to do it ourselves if I ever get the time. I'll keep everyone posted.
Chris
Old Aug 15, 2003 | 03:48 PM
  #30
ravencr's Avatar
Here's the plan:
I'm either going to use 6" or 5" C-Channel that's about 1/4" thick and replace the entire front bumper. It's going to be straight across the front, with two bends in the side to fit the contour of the truck. The ends will end up just inside the front fender flares, which should look really good. Then, in the center a 36" skid plate will go from the bottom of the bumper to the lower frame rails and then bolt into the existing skid plate underneath for a completely protected and much better approach angle. I'll reinforce the side of the skid plate and have 1"x1/4" flat stock that runs from left to right on the skid plate to reinforce it too. I'm probably going to paint it the same color as my fender flares so it blends nicely.
In addition, I'm going to mount driving lights and fog lights within the bumper that will be slightly recessed and well protected, along with some side marker lights that will only kick on when I turn my turn signals on. It should be pretty sweet, but it's going to take some time for sure.
Chris
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
ktm192k
Oct 1, 2015 08:47 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
justdifferentials
Sep 5, 2015 06:52 PM
