any good/reputable brake shops in the L.A. area?
Just got a set of Brembo rotor blanks and a set of new pads and don't trust my abilities to tackle this task on my own. I just want to drop off my rig and have it done right no questions asked. Or, I wouldn't mind having one of you Yota-heads doing this for me and paying you for your time (or I can toss in some adult beverages maybe). One more question, do the front wheel bearings need to be replaced as well during the brake job?
Oh, almost forgot. I still haven't had the chance to put on my SAWs yet either
. C'mon, help a brotha out!
its a piece of cake to do brakes on a taco
1. remove wheel
2. remove the two 17mm bolts holding the caliper to the knuckle, remove caliper
3. compress all 4 pistons back into the caliper
4. remove old pads install new pads
5. slide old rotor off wheel studs, slide new rotor over wheel studs
6. replace caliper
7. do other side
8. pump brakes before moving
9. done, enjoy a beer
but if you still want someone else to do them, I'm sure some Yotatech person will help you, personally i wouldn't take it to a brake place
1. remove wheel
6. replace caliper
7. do other side
So it's that easy, huh, Joe? Hmmmm. Do the brakes need to be adjusted in any way after replacement of the rotors and pads or will they adjust on by themselves? BTW, do the bearings need to be repacked?
Originally Posted by TDiddy
Its easy as long as you can get the caliper bolts free. I couldn't budge mine and don't have air tools, so I took it somewhere instead of snapping the head off.
Gee, greaaaaaat. That's a comforting thought....
Very straight forward. Pick up a Chilton manual if you want directions.
PM me, I'll help you out......
Thanks for the offers, fellas! It's gonna be some time because my dad just have a quadruple heart bypass surgery and he's still in the hospital so I'll need to figure when I can free up some time. TIA guys!
polo451
13
Nov 20, 2016 07:49 PM
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
Sep 22, 2015 07:28 PM
Sep 4, 2015 09:27 AM
