Another bodylift completed!
Old Nov 19, 2004 | 08:51 AM
  #41
uboatcmndr's Avatar
Originally Posted by turboale
Thanks man!
I'm not sure when I'm going to get the bigger meats. I might ask for another set of wheels and tires for christmas then put the 285s on some alloys and get some 33" Destination MTs for the Tech1s. There is no way I can fit 35s because of my limited flares. Believe it or not the 285s are a little on the close side . I just don't want to have holes all over the side of my truck.
I don't know about the limited's fender flares explicitly, but on my 2000 I had those painted ones that were about 2'' wide. I took them off and filled the holes in the body with black plastic pop in fasteners for automobiles I obtained at Lowe's Home Center. I painted them OEM silver because the color of my rig. Of course my issue was not with tires rubbing, at least not yet, my issue was they are just something else to get in the way of wheelin'.
Old Nov 19, 2004 | 08:56 AM
  #42
turboale's Avatar
Doc,
Thanks for the complements. And yes those are the 17" sequoia/tundra wheels on HoJu's rig.
UBoat,
Do you have any pics of the finished product? I don't mind the flares because they protect the body and actaully have saved me a few times, I just don't like the holes. I think the bushwackers look a lot like the stock ones but I don't know if they stick down like the yota ones. I don't know if the bushwackers will cover the holes from the OEM ones
Old Nov 19, 2004 | 08:59 AM
  #43
uboatcmndr's Avatar
Cool
Doc,
UBoat,
http://f2.pg.briefcase.yahoo.com/mom...@sbcglobal.net try that my good sir. I have often wondered if Bushwacker or such used the OEM holes.
Old Nov 19, 2004 | 09:09 AM
  #44
slyang1012's Avatar
Thanks man!
are 33's equivalent to 285's?
Old Nov 19, 2004 | 09:12 AM
  #45
uboatcmndr's Avatar
Smile
285/75-16 equals 33"x12.5''-16 This will make yer head spin....http://www.tirerack.com/tires/tirete...nformation.jsp
Old Nov 19, 2004 | 09:25 AM
  #46
turboale's Avatar
actually not...
they are slightly smaller... its like 32.8 or something... I also want to get MT (mut terrains) which usually run big because of the more agressive tread.
Old Nov 19, 2004 | 10:05 AM
  #47
HOJU's Avatar
actually a 285/75R16 is more like a 32.8x11.4x16
a 305/75R16 is more like a 33x12.50x16
Old Nov 19, 2004 | 10:48 AM
  #48
TStango's Avatar
Austin,
Looks great man. If you want to go bigger on the meats make sure you do it. What sucks is that the Firestone Destinations only come as 285's for the 16" rims. I want those tires too but 285's aren't as beefy looking as my 305/70/16's. I just swapped out my 305's for my 285 Revos, mounted on the stock rims, last night. I figured it'd be good for the winter months. Too bad my rig looks like a PU-C mobile now.
Old Nov 19, 2004 | 04:17 PM
  #49
waskillywabbit's Avatar
body lifts schmody lifts...my lift makes my 35s look small...and if I ever actually see daylight again with my work schedule I'll take some pics...
Looks good Austin...
Old Nov 19, 2004 | 07:12 PM
  #50
justinh's Avatar
Doc,
UBoat,
we'll get the 35's on there, they are going to fit on mine after my body lift, i don't care how much trimming i have to do. it is the back of the fender where people usually run into problems and they really don't stick out much in the back. we'll see though. i have a plan b if i have to cut too much, and that is cut more and then do what they did with that lexus gx470 in four wheeler magazine, tape up all the holes and rhino line the rocker panels or i may just take it to a guy i know have him fill them for me. regardless, i have to go there because of the gears i bought, so i will let you know what is needed. and if you want a cheap set of 35" for 17" wheels let me know.
Old Nov 20, 2004 | 10:55 AM
  #51
HOJU's Avatar
Justin, you need to send me some pics when you've gotten the 35's!
Old Nov 20, 2004 | 12:49 PM
  #52
justinh's Avatar
i will, i don't know what i am going to do to fit them yet, but they are going on, i don't really care what has to be done. i am not sure which sequoia wheels i am going to use, the grey/silver ones are $95 a piece at discount tire and i can get the gunmetal/bronzy colored ones for $100 a piece from a guy i know, with the white and silver on my 4runner i will probably go with silver ones although i like the gunmetal color more.
Old Nov 20, 2004 | 12:53 PM
  #53
turboale's Avatar
Whats the backspacing of those wheels? I can't imagive they are that wide? I'm sure you had to add spacers right HoJu? I mean, your stance is HUGE!
Old Nov 20, 2004 | 01:00 PM
  #54
HOJU's Avatar
my wheels are right off of a 2004 Sequoia, not the knock off's... they're 17X7.5's with 5" bs and i used 1-1/4" wheel spacers from marlin crawlers...
Justin, are you dead set on the Sequoia wheels? cause these would look good too....
  #55
justinh's Avatar
i asked him the same about the spacers because i had been anticipating using them, i think he said he is running 1.5 spacers all the way around. the back spacing on those is right around 5". i think they are 7.5" wide so they are a little wider than ours as well, i would love to send a set off to get beadlocked like brucets has done with his stock wheels as that would add around 1" to the width.
Old Nov 20, 2004 | 01:21 PM
  #56
justinh's Avatar
i have seen those too recently. i like those as well. i think they have even more backspacing though and i probably can't get those for less than $100 per wheel. i really like the tundra/sequoia wheels, if i hadn't just bought tires when they came out i would have had them a year ago.
Ktm526
Oct 7, 2015 05:14 AM
_Nicco_
Sep 21, 2015 03:06 PM
SharpStick
Aug 29, 2015 12:59 PM
mtb_taco
Aug 20, 2015 12:16 PM
