Which Amsoil to run in rear end with a Locker? OK to switch at 125k??
Old May 31, 2005 | 07:57 AM
yoda-g2's Avatar
I'm getting tempted to switch out my rear end juice with some good 'ol Amsoil. I figure this would help keep the gears a little coler when towing my 40 around. So my three questions are:
1. Is it safe to switch rear diff fluid to synthetic at 125k?
2. What weight/style should I get with my locker? (I'm in eastern WA so cold winters, and hot summers)
3. What is the capacity of the rear end?
I just did my tranny and plan on slowly switching everything out eventually.
Old May 31, 2005 | 09:57 AM
4Runner4Christ's Avatar
1. You should be fine switching over.
2. You will want Amsoil 80W-90 (Amsoil# AGL-QT)
3. The capacity is about 2.5 quarts, so get three! Good luck!
BTW, you might consider replacing your drain & fill gaskets. The Toyota part# for both is 12157-10070.
Old May 31, 2005 | 08:24 PM
kyle_22r's Avatar
no problems from switching to amsoil in a rear end. there's only 3 oil seals and 1 gasket in the whole setup -- not something that's prone to leaking anyway.
Old Jun 1, 2005 | 02:52 AM
aowRS's Avatar
Surely you jest. He has a 3rd Gen....
Andreas
Old Jun 1, 2005 | 08:17 AM
yoda-g2's Avatar
Thanks guys!
I went ahead and picked up enough for the tcase and front diff as well. I figured I might as well bite the bullet and do it all at once.
I just hope I don't cause any leaks by switching. I'm assuming that it doesn't matter as much as switching over engine oil at high miles... fingers crossed....
Old Jun 1, 2005 | 05:11 PM
george16's Avatar
You should be alright. I switch my diffs, tranny and xfer case to 75-90W synthetic and i still have to find any leaks.
George
stagger_lee
Mar 29, 2016 06:27 PM
red88toy
11
Aug 3, 2015 07:47 PM
bigblue82
10
Jul 6, 2015 08:27 AM
merc1100sc
Jun 26, 2015 05:24 PM
