alternator or battery problem?
got a 91 4runner w/ 140k. original alternator. here's the symptoms:
-on cold start, truck struggles just a bit to start, as if battery is low on charge.
-at idle, my headlights go dim (of course, only noticeable at night) and brighten up when i hit the accelerator.
-at idle, the heater doesn't blow hot air. only does so when i'm on the gas.
i'm guessing alternator.... sound right?
thanks,
Deo
thanks,
Deo
Actually, mine did this right before my Alternator went. And now I am having more problems in terms of it. But its going to to the shop on friday to be fixed (hopefully anyway) for good. If you can, see about getting the alternator tested.
taller1
Nov 13, 2018 02:34 PM
