The age old question OME 890 vs 891
Old May 13, 2008 | 02:45 PM
  #41
twitchee2's Avatar
nice let me know how it is.
I gave in and paid a shop $39 to put both in in 45 min. works for me.
Old May 13, 2008 | 02:48 PM
  #42
glenyoshida's Avatar
Originally Posted by twitchee2
how is the world do you get the top shock nut off?!?!?!? i couldnt get it off for the life of me.
Take a piece of rubber sheet or something like an old rubber glove and use it as a grip base for flat rope to tighten around.
Tie a loop in one end of the rope. Pass the rope through the loop so it self tightens. Make several wraps around the shock.
Make a second loop on the other end that you can put a breaker bar into for leverage. Then use an air ratchet to loosen the top nut.
Or you can just use a pipe wrench and mangle the thing as you are taking it out. lol
Old May 13, 2008 | 03:21 PM
  #43
crolison's Avatar
My 891's get in friday, and then the lift is going in, i am gettin antsy right now. My front lift is sitting in my room, just waiting for the rear to show up.
Old May 13, 2008 | 03:27 PM
  #44
twitchee2's Avatar
congrats. post up when you get it. I got my shocks in and ride is 100x better. im so excited.
Old May 15, 2008 | 04:51 PM
  #45
cocoslow's Avatar
Can I get 33s on with the OME 2" set-up? Will there be any rubbing when off road? Will I need a diff drop?
Thanks.
Old May 21, 2008 | 12:33 PM
  #46
twitchee2's Avatar
so i cant really decide but im starting to think 881's for the front will be better?
Old May 22, 2008 | 05:43 AM
  #47
Ron Helmuth's Avatar
twitchee2 I picked 881 for my front springs because I am running the ARB bumper. I believe the rating is something like +130 lbs over stock.
I have read that 880s or 881s are pretty similar.....if you are stock I think 880s for you are likely best-unless you will be adding some weight up front.
just my .02
my lift should be here in a week or so. 881s front and 891s rear
Old Jun 6, 2008 | 06:55 PM
  #48
cocoslow's Avatar
Just to let you know from someone who learned the hard way; the lower spring holder for the front OME front shocks is mounted so the spring sits inside the cupped part.
Old Jun 9, 2008 | 05:49 PM
  #49
Gerdo's Avatar
I swapped out my 890s for a new set of 891s. I also just added a Panhard Bar drop bracket (Toytec). I drove with my 890s for a couple of years and switching to the 891s isn't a big difference in ride. If someone snuck in one night and switched the springs I probably wouldn't have noticed.
I did notice a big difference having the PHB drop. The rear would swim a little when going over bumps. With the PHB drop it calms things down. It makes the PHB more level and so the up/down arch is now mote vertical. Before, the arch was more in/out. Well worth the $50.
I just got back from a trip. 3500 miles towing and the springs, 891, are great.
As Glen did mention. The 891s are shorter, out of the vehicle, but I did get about 1/2" more height than the 890s. There may/should be some settling tho.
Old Jun 10, 2008 | 05:02 AM
  #50
crolison's Avatar
I really need to get a new panhard bar, or a drop bracket. On the highway when i hit bumps it wanders a little in the rear.
Old Jun 10, 2008 | 04:54 PM
  #51
Gerdo's Avatar
Old Jun 10, 2008 | 05:12 PM
  #52
Gerdo's Avatar
I didn't think that I NEEDED a PHB drop. My axle wasn't pulled too far off center but the arc of the PHB after the lift would move the axle left and right. Now the PHB moves more straight up and down.
I used the Toytec Panhard Bar Drop . You will want to cut a spacer for inside where the PHB used to be so you don't crush the bracket. You can use almost anything, square tube, round tube, a stack of washers. You will also want to weld the drop on so it doesn't move. I had to grind a little to get the bracket on.
Old Jun 10, 2008 | 10:18 PM
  #53
twitchee2's Avatar
nice. Well i had to do something about my rear sag plus ive been doing lots of moving (out of dorms, moving out of my parents, then back to arptmt at school) so i had to do something about it. I got some air lift 1000's and so far its been perfect for what i need. I cant afford to lift the front yet so i just opted for the air bags. So far they are great and i get as much as 1.5in higher then the front when empty then it holds it fairly well with weight. They came with 2.5 spacers so it will still work when i get my lift so i think im just gonna get the 890s over the 891s. I think the air bags will make up for the carrying capacity of the 891's. What do you think?
Old Jun 12, 2008 | 11:29 AM
  #54
Gerdo's Avatar
I had the air lift bags on mine for a while. They ride nice, eliminate the sag and handle a load well.
The one thing I didn't like was when I was offroading I had the supply line pull out of the bag. When the axle is articulating the bag will stay centered in the coil and lift off the spring perch. I had quite a bit of slack in the air line but when the axle would drop the line would get caught on the hole in the spring perch and pull out. If I made more slack then under normal driving there would be alot of line hanging down.
I decided to swap them out for my lift (TRDs & 890s). Since going to the 891s and with the heavy loads/towing that I do I know that I'll be happier with the 891s.
Old Jun 12, 2008 | 01:05 PM
  #55
twitchee2's Avatar
thats good info. I took that into consideration when i installed them and left enough slack to allow them to drop all the way down. I will see how they handle when i pack the truck up again and then throw a trailer on top of it all. One think i thought was very cool was the fact that they included 2.5in spacers so i can still use them when i get my lift.
Old Aug 7, 2008 | 11:30 PM
  #56
For grins I weighed a few things tonight.
Stihl 26 Chain saw weighs 15 lbs
4 foot Hi-Lift weighs 28 lbs
exactly 5 gals of gasoline in a Nato gas can with the spout is 42 lbs
Yokohama Geolandar MT+ 305/70R16 on MB Motoring Blitz rims 85.5 lbs (new)
Old Aug 8, 2008 | 10:59 PM
  #57
boostedka's Avatar
i installed 891's with ome firm shocks and saw 2.0's up front and it rides smooth!
Old Sep 30, 2008 | 04:25 PM
  #58
twitchee2's Avatar
Gerdo how much weight do you carry with the 891s? Im still debating and im planing on getting my lift after the first of the year.
Old Oct 1, 2008 | 05:58 AM
  #59
Gerdo's Avatar
Most of the time I drive around with nothing in it. I do tow and sometimes have 300# tongue weight. I also have had about 800# inside.
Old Nov 2, 2008 | 04:33 PM
  #60
Gerdo's Avatar
I still like the 891s on the road and they did give me about 1/2" more lift. They also handle my trailer better.
After a couple of wheeling trips on the 891s, there are a couple of things that I prefer with the 890s. The 891s do fully compress when flexed but there is a "springy" feeling (yah I know they are springs) that I didn't have with the 890s. The 891s compress then bounce back compaired to the 890s would compress and not spring back. On my last trip I was on an off camber trail and there was tree root on the high side. When I drove over it, with the rear wheel, it felt like it was going to catapult me onto my roof.
I think I'm going back to my 890s with a 10mm trim packer.
nvdesertrunner
May 11, 2020 08:18 PM
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 4, 2015 08:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
rushw
Jul 18, 2015 01:46 PM
