Advice on worn clutch
Old Aug 3, 2005 | 09:12 PM
phorunninduke's Avatar
Originally Posted by flyAddict
Quote from the mechanic on invoice:
"...Take car on extensive road test, experience 1) clutch slipping and chatter, 2) clutch bearing noise. 3) rear bumper hook noise [aka shackle clap as i call it] Check steering, suspension, axles, universal joints, motor mounts and general check of possible problems, find no major problems except that clutch is needed. Reroadtest with customer-still no noise..."
This translates to :
Took car on a long lunch brake to the strip club, exsperiance 1)burn outs - clutch slipped a little, 2) Noise bearing from the broken transmistion peices from burn out test. 3) Hooker rash on rear ( aka the clap as I call it )
Old Aug 4, 2005 | 10:08 AM
Flamedx4's Avatar
When a manual transmission slips it acts just like an automatic transmission - when you step on the go pedal the engine makes more noise and uses more fuel and more heat is generated but not much 'go' comes out of it....
Old Mar 30, 2008 | 01:52 PM
1991SR5V64X4's Avatar
Have any of you guys, had, or heard of a Sudden failure, = No Clutch, just that special smell, & Big rigs FLYIN by as you pull over, 137K original miles. Slave & master ok. Hope the trans is ok.
Thanks
Old Mar 30, 2008 | 04:04 PM
rowdy235's Avatar
my cousins clutch on his 89 ford went out all at once. Its not common, but also not unheard of
he's gone
7
Dec 3, 2019 07:08 AM
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
Iceman4193
Aug 28, 2015 08:43 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
1996Taco
Jul 20, 2015 12:02 AM
