Adding tranny fluid
Old Apr 16, 2003 | 04:56 PM
az4x4runner's Avatar
Question Adding tranny fluid
I was thinking of checking my tranny fluid level, and maybe topping it off, I don't know what fluid my tranny has in it, would it be ok to add some that I bought at a store a long time ago?
Also, what are the correct steps in checking the A/T fluid level?
Thanks a lot,
-Bryan
Old Apr 16, 2003 | 05:03 PM
CTB's Avatar
CTB
Most cars you check the Tranny fluid while the car is running, and on some, you check it with the tranny in neutral. Look in your owner's manual or on the tranny fluid dipstick, and it should tell you what procedure to use to check it.
Also, it should list what type of tranny fluid to use in your owner's manual or on the dipstick. And just like checking your oil, add it till it reaches the proper level on the dipstick!
Old Apr 16, 2003 | 05:15 PM
rabidbeaverbaby's Avatar
for my 2nd gen (92) with the 3.0 auto you start at P (with the engine on) and go through each gear pausing for a sec and then back up to P and check the tranny oil (with the engine still on) like you would the engine oil.....i've noticed that if my engine is really hot that the reading will be a little off....so i usually let it cool off a bit and then check it.................
my truck uses ATF Dexron (sp?) II (it says D II on the train plug)
Old Apr 16, 2003 | 08:12 PM
Tacoma Dude's Avatar
Can you just add?
I thought you had to flush the whole thing out?
Old Apr 17, 2003 | 03:49 AM
yea you should add some to bring her up to level.....periodically you should get it flushed...i don't know about using old stuff but you can by a new quart for a few bucks....
crammit442
7
Nov 29, 2017 12:30 PM
Poppie51
Aug 2, 2015 11:29 PM
yourrealdad
Jul 21, 2015 11:13 AM
Iceman4193
Jul 15, 2015 04:48 PM
