AC blowing on driver's feet
Old Jul 25, 2010 | 09:29 AM
Citykid's Avatar
I have all the lower vents closed. But see the open space next the the 4 in a circle? Cold air blows out of that to the point on a long drive my right foot is freezing. This is to the right of the gas pedal. Does anyone else have this opening? I was thinking of just blocking it up. Maybe get some more cold air coming out of the vents also.
Old Jul 25, 2010 | 12:30 PM
eddieleephd's Avatar
I have the same opening and to me it sounds like there is a vacuum line off.
if you use a piece of foam or something that would probably work. I would guess .....
Old Jul 25, 2010 | 12:46 PM
1990yota-pickup's Avatar
masking tape.. leaves no sticky reisdue
Old Jul 25, 2010 | 06:08 PM
Citykid's Avatar
Yeah, but why all of a sudden? I've had this truck for almost ten years now.
Old Jul 26, 2010 | 02:20 AM
vacuum lines get brittle and break.
and only the blue tape leaves no residue
Old Jul 26, 2010 | 02:57 AM
LINY4Runner's Avatar
off topic- CityKid, I see you're from Long Island too...you ever go out on the beach with the Runner?
Old Jul 26, 2010 | 07:42 AM
Citykid's Avatar
LINY, I always mis the deadline for the permit to o on the beach. But I do hear a lot of stories of many vehicles getting stuck with the exception of 4Runners & Wranglers. LOL.
Old Jul 26, 2010 | 08:20 AM
TheDurk's Avatar
Do you have the automatic (digital) or manual A/C control? If its the automatic, your A/C mix servo may have gone out. If manual, the mix control cable may have problems. Both can just happen with age. That opening is the normal floor discharge. There is an amazing diagnostic routine for the auto A/C in the FSM--the thing can diagnose itself.
Old Jul 26, 2010 | 11:04 AM
Citykid's Avatar
I have the manual. Old fashioned dial you have to turn with your hand. LOL
Old Jul 26, 2010 | 03:00 PM
fix it already it cant be that hard...
Old Jul 26, 2010 | 05:20 PM
I am going to guess you have never torn apart a dash and found a broken vacuum line....
Sure to plug it and such is very easy, however to fix it will be a pain in the arse!!!
Old Jul 27, 2010 | 03:24 PM
my little yota dont have the a/c system.. my big f250 hd edt. does and yes it has a pile of vacum lines to the push button control..
harbor frieght mittyvac. hand vacuum pump will pay of when hunting for vacuum leak..
it was worth every pennie..
sometime its easier just to take it to the pro's and not stress your self out over the small stuff..
Old Jul 27, 2010 | 03:28 PM
B4Runner's Avatar
that hole leads to a "vent" that comes out at about knee level directly below the steering column
Old Jul 27, 2010 | 03:31 PM
typically if the vent line clogg up you will build alot of condesation up in the truck..
jashoeuh
Nov 18, 2024 08:08 AM
theking11863
Mar 19, 2016 09:36 PM
Swim
9
Jan 4, 2016 10:47 AM
RobotMoose
Sep 2, 2015 05:53 AM
coryc85
Jul 6, 2015 04:07 AM
