ABS Rotor and collar on axle help
Old Apr 30, 2008 | 07:44 PM
98runner210's Avatar
Guys,
I had my wheel bearing fixed and i think they pressed the collar on too far. Same thing happened on the other side. The collar doesnt go all the way against the rotor. When it is like that, it doesn't seat on the inner axle tube seal like it should causing it to leak. Does anyone know the measurement for the collar?
Here is a pic:
Old Apr 30, 2008 | 08:41 PM
toytech76's Avatar
There are actually 3 different space measurements depending on the vehicle and package. I dont know them offhand. We built 3 measuring tools that we just hold up the the axle when we are pressing on the collars. Best way I can tell you to do it is to put the axle in and then pull the abs sensor out and see if you can see the tone ring. When the tone ring is centered in that hole you know you have it right since that collar rests against it
Old Apr 30, 2008 | 10:20 PM
i wonder if i can measure the the end of the tube to the seal and then apply that to the axle
Old May 1, 2008 | 12:15 AM
KZN185W's Avatar
Originally Posted by toytech76
.... When the tone ring is centered in that hole you know you have it right since that collar rests against it
shouldn't the ABS rotor be centered on the abs sensor hole instead of the tone ring? The ABS sensor's teeth needs to hit the rotor's teeth to be able to "sense" locking of tires during braking.
Old May 1, 2008 | 04:51 AM
toytech76's Avatar
abs rotor = tone ring
Old May 1, 2008 | 07:54 AM
Thanks for the tip, I will pull the sensor out and look in to see which way the rotor and collar need to move.
Old May 3, 2008 | 01:01 AM
KZN185W's Avatar
my bad.. i thought tone ring = bearing lock.
Thanks!
88sasturbotoy
Jan 30, 2026 01:57 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
klavender1
Aug 15, 2015 01:51 PM
JimiJams
Aug 7, 2015 01:36 PM
ty1er
Aug 1, 2015 11:53 PM
