99 Runner problems
Old Sep 1, 2011 | 03:29 PM
swamp_fox's Avatar
Well....left work early to go swap out my NGK's for some original toyota plugs....picked up some wires while I was there.....$100 later.......came home, cleaned the MAF, cleaned the throttle body, changed the plugs, changed the wires.......PRESTO...no more problems.
#4 had a substaintially larger gap than the others.....and 5 of the plugs where the same type and 1 was a different one.....all NGK. One had a 2 pronged end and the others were single.
Thanks again for the help guys! I plan on keeping this 4runner forever.
Old Sep 6, 2011 | 07:28 AM
sdsurfer's Avatar
Nice job. Happened timeworn as wires. It would warm up.and not miss. But cold JE y would. At time if removal, the wireswerewarn out and one even broke. Keep on runnin!
Old Sep 6, 2011 | 08:00 AM
Fink's Avatar
Good to hear man! Glad it all worked out.
Fink
Old Sep 6, 2011 | 01:51 PM
trx125's Avatar
You need to use the NGK's with the dual electrodes in the 3.4l. Single electrode plugs will burn off prematurely and fall into the cylinders. I ask me how I know!
Old Sep 7, 2011 | 09:08 AM
  #25
smokey0066's Avatar
Densos are dual electrode too. OEM comes with denso on one side and ngk on the other. Either will work. I've used NGK on the last 2 replacements with no issues.
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
Mr.Black
Jun 21, 2015 10:17 AM
stunner_runner
Jun 17, 2015 05:35 PM
