99+ Fog Lights are junk.
Ian,
My 2000 fog lamps work no problem, I am just disappointed about how it only lights up three feet in front of the runner. Did you just replace the bulb with 100W, on a STOCK wiring harness? If so, how are your fog light wiring holdin up? I have heard horror stories about people repalcing just the bulbs and melting their stock wiring harnesses.
austin
austin
Ian
Originally Posted by pfdaxe
HB:
Can you post a pic of the Hellas you received from the side? I'd like to see the length of them
Yea, they appear to, but it might just be a better marketing picture.
They're made in Germany. I'm tellin' you, the lamp bodies I linked above are EXACTLY the same as the OEMs. Right down to the numbers imprinted on the lamp bodes. Yea, the brackets that came with them are different, but that's why I mentioned in my original post that if you ALREADY have the OEM brackets, then the ones I linked above are direct replacements.
If I get some time. Won't be able to host them till Monday, but EVERYTHING about the lamp bodies is indentical.
#25
#27
I was curious on how you wired up your all the lights. I agree the Runners are under wired. I wanna know how you wired them up to the relays? So far, I have upgraded my head lights with a higher wattage bulb, but I UPGRADED the wiring. By upgrading, I just bought a wiring harness that was made with a thicker gauge wires that connected between the new higher wattage bulb and the stock wiring harness. Please enlighten me on how you have yours setup. Thanks.
austin
#29
pfdaxe:
I've got a couple side-by-side pics of both my old OEM lights and the new ones. I'll post up tomorrow (can't get to my hosting site til then). The H3 bulbs mount from the rear on both the new and the old OEM set.
#30
#31
New vs old comparison pics.
Here some shots of the new vs. old OEMs:
I repainted everything, and its all remounted. I decided to re-use the OEM connector with the new rubber boot which covers the rear of the lamp body since the old one was full of corrosion. So, I cut off the Hella connector and soldered the OEM Toy connector on (didn't want to rewire the whole truck).
#33
Mine look like these.
After searching trdparts4u's replacement parts, maybe there's a different between "Dealer Installed" and "Factory Installed".
#35
#37
I would have to agree with KZN185W because I looked into changing mine out with the Hellas but they are not Hellas...they are Koito. But then again, it could be model and year specific....I have a 2000 Limited. So question becomes...can I replace the FACTORY fog lights with these:
http://www.rallylights.com/hella/Micro_DE.asp#4runner
Part number: HL74560
Or am I gonna have to order them from the dealer???
#38
#39
H3c vs. H3 HID bulb...
I may install the H3c HID bulbs versus the H3 bulbs to maintain the same focal point. By using the longer H3 hid bulb, my beam pattern and/or cut off maybe affected. Thoughts??
