99 4Runner Limited 4x4 front lift help needed
Old Oct 21, 2011 | 05:06 PM
99SC4Runner's Avatar
I've got a 99 4Runner Limited 4x4 supercharged that I want to level up the front to the back.
It never sat totally level since I got it.
It used to have the following suspension on it with ear raked up higher;
Front
Stock tall 99 Limited coils on OEM struts
ToyTec 3" spacer lift
Diff Drop kit
Rear
OME 891 coils
Monroe Air shocks (set at 10#)
Now it has the following suspension on it;
Front
2004 TRD Tundra 4x4 front coils with new Gabriel Gas struts
ToyTec topout spacer - 1/2"
Diff Drop kit
Rear
OME 891 coils
The front still sits lower then the rear. I also have an ARB Sahara front winch bumper with a Mile Marker 9500# winch on the front. I think the both of them probably weigh 200#.
I measured the front from center of hub to the limited flare lower corner and it was 22 1/8".
The rear measured from center of hub to the limited flare lower corner and it was 23 1/8".
I was researching some ideas to level it up and the only things I can think of is;
1. Put OME 883 coils up front with maybe the ToyTec 1/2" topout spacer.
2. Put ToyTec/Eibach 3" front coils in that have a 620 # weight rating to them.
3. Find a 1" topout spacer to add to the top to get the extra 1" I need to get this 4Runner leveled up.
I just want some ideas from others on here that probably has messed with different combinations to get their 4Runner to sit level.
Thanks,
Doug
Old Oct 24, 2011 | 03:05 PM
I'm just getting a set of Tundra 5100 adjustables so I can get better ride quality up front since I have the Sahara ARB bumper and MM 9500# winch, and I can adjust the ride height of the front of my 4Runner.
Old Oct 24, 2011 | 03:27 PM
Doug18's Avatar
You have alot of weight upfront Doug ... maybe you could get 2" lift springs for tundra?
Old Oct 24, 2011 | 11:34 PM
The TRD Tundra front coils I'm already using is supposed to give a 4Runner a 2" - 2.5" lift by themselves.
Old Oct 25, 2011 | 04:24 AM
waskillywabbit's Avatar
I have the adjustable coilovers on my Tundra and you can set them where you want and the ride quality is still great.
:wabbit2:
6th Gear
19
Dec 10, 2019 07:31 AM
Bamripzit
Jul 19, 2015 01:17 PM
Bamripzit
Jul 13, 2015 07:21 PM
88Toy
7
Jun 17, 2015 09:40 AM
HALMAN
Jun 14, 2002 09:02 PM
