98 5speed 4x4 code P0500
Old Oct 8, 2021 | 11:40 AM
Salty4Life's Avatar
I have a 98 T4R manual 4x4 with abs codes 31 33 34 49and a check engine light that returned code p0500. Speedometer it intermittently not working. Attached are pictures of the scanner. I’ve already cleaned the three wheel speed sensors and still nothing. Please advise next steps.
Old Oct 11, 2021 | 04:43 AM
Salty4Life's Avatar
I swapped the ABS ecu with one from a 2000 automatic. At fist the abs light was off but the check engine light was still on and Speedo non functional. Second time starting the car the abs light was back on. This time with codes 31 32 33 34and 41. I want to swap the vss next. Would it be the same part from a 2000 automatic as a 98 manual? What are the one part numbers for each? I found 15 different ones that all look different online.
Old Oct 12, 2021 | 08:03 PM
moto809's Avatar
5 Year Member
I'm not a Toyota master tech, but I've been turning wrenches for 30 years. There's a process of elimination you can take to resolve problems like this. The fact that 0500 mentioned the VSS 3 out of 5 times strongly suggests that should be where you look next. As far as finding the right one... if there are 15 different ones, you need to pull yours out and compare it to what you see in pictures.
Sorry I don't have a magic fix all answer, good luck.
Old Oct 13, 2021 | 05:20 AM
fierohink's Avatar
Rockauto lists the same part # for 4wd/auto for ‘98 and ‘00, but a different part # for rwd/manual.
you may need to go to an auto parts store and look at them and compare.
toyospearo
Jul 16, 2010 12:39 PM
bak3rme
May 7, 2010 12:46 PM
FL.Cowboy
Apr 2, 2010 09:03 AM
turkeykiller365
Dec 2, 2009 11:41 PM
wormhole
Dec 22, 2006 05:02 PM
