97 5spd shifter problem
Old Sep 18, 2009 | 02:53 PM
Masonn's Avatar
Hi, I'm Mason, and I drive a 1997 4runner 4WD with the 2.7L engine and 5spd transmission. I'm currently having problems with the shifter.
I read up about the 5spd shifter problem (http://www.brian894x4.com/Shifter.html) and I took mine apart. I found something wierd.
This is how it's suppose to look:
and this is how mine looks:
It looks like I'm missing a stud on one side. How should I go about this?
I just got off the phone with my local autowrecker, and they don't have any transmissions in stock to take this part from. What now?
Old Sep 18, 2009 | 04:28 PM
scuba's Avatar
Put a new small studs in it..?
Old Sep 18, 2009 | 04:29 PM
Masonn's Avatar
I'm not sure if they can come out or not. I'll go check.
Old Sep 18, 2009 | 07:46 PM
Dvold's Avatar
Neither one of those pictures are correct. You should have a flat rubber washer under a cup in there. The top pic shows what it looks like when the cup disintigrates. The shift tower is easy to replace. 4 bolts and it's done. You should be able to use the shift tower from any 89 and up R150 5 speed. This will, of course, take care of the missing pin.
Old Sep 18, 2009 | 07:52 PM
Dvold's Avatar
Just reread your post and it appears I missed the 2.7 part, DOH! You have the "W" trans. Same idea though.
Michael oaks
Jul 27, 2015 11:47 AM
tobylab
Diesel Swaps
Jul 17, 2015 06:51 PM
Iceman4193
Jul 15, 2015 04:48 PM
crashburnoveride
Jul 10, 2015 06:39 AM
