97 4runner overheating
Old Nov 10, 2012 | 05:01 PM
dbryant's Avatar
Have a 97 4runner 3.4L over heats only when driving, takes about 5 min factory gauge will peg in the red. Installed mechanical gauge it will read about 240 checked with external temp probe, it shows 215 at the top radiator hose housing (gooseneck on intake). Has 212000 miles. Things done, new bearing, rings, water pump oil pump, new gaskets on everything heads have been machines, new temp switchand temp sensor, new crank sensor, radiator has been rodded and cleaned, new Toyota thermostat. Any ideas would greatly help I am at a loss
Old Nov 10, 2012 | 05:19 PM
rworegon's Avatar
Head gaskets installed upside down? Post 54, 56.
https://www.yotatech.com/forums/f2/9...tumped-245391/
Did you use Toyota OEM HG?
What was the temperature before the engine work?
Old Nov 10, 2012 | 05:36 PM
dbryant's Avatar
Head gaskets on right, don't remember what the temp was, isat for 4 years before rebuild. It did blow a head gasket that was the reason for rebuild. Not OEM HG
Old Nov 10, 2012 | 05:40 PM
rworegon's Avatar
Is the thermostat opening at the proper temp?
Cooling system is totally burped of air?
Fan clutch is working?
Did you have the heads pressure tested?
Old Nov 10, 2012 | 05:59 PM
dbryant's Avatar
Fan clutch is working it was checked recently.
System as far as I can tell is burned but not 100% sure.
One head was replaced. Plugged oil passage it is good the other head, not sure if it was pressure check when I had it at machine shop. Have not checked the thermostat to ensure it is opening. I do know.that the radiator.is hot on the top half and goes from warm to almost cold as you move towards the bottom. Bottom rad hose is slightly warm when it shows it is over heating.
Old Nov 10, 2012 | 06:07 PM
rworegon's Avatar
Something is seriously blocking the coolant flow or exhaust gases are still getting into the coolant and heating it up. Was a rag left behind in a outlet or hose in the cooling someplace?
You might pick up a Block-Check kit to see if exhaust gases are in the coolant.
Old Nov 10, 2012 | 06:17 PM
rworegon's Avatar
Maybe a mod can move this thread to the proper forum also.
Old Nov 10, 2012 | 06:23 PM
dbryant's Avatar
Sorry new to the forum didn't know where to post. Gonna do some more checking tomorrow. Thames for the help so far and sorry if I posted in the wrong area....I'm just a newbie...lol
Old Nov 10, 2012 | 08:12 PM
vital22re's Avatar
totally a bro
When you filled the radiator did you leave a heater hose unconnected to allow the air to burp out? More than likely you have no coolant in the block and just the radiator. I've seen that happen many times. I'll also remove the upper hose from the radiator and fill into the upper hose so it fills the block first.
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Rkellerman
Jul 12, 2015 08:42 AM
Avenged
Jul 9, 2015 07:55 AM
