97 4-runner w/ 5sp & 5vz-fe clutch issues
Today I was driving home and was going up a hill and felt some slippage in 5 gear as well as 4th.
I am curious about what this may be. My first guess is the clutch, I am new to the ownership of the yota and was told by the previous owner that he replaced the clutch 1.5 years ago. I am calling BS on that. But before I tair into the clutch I was just wondering if there other things I should check before I do this.
Help is much appriciated.
If its slipping, I would be looking at the clutch. First, make sure the clutch is adjusted to specs according to your factory service manual. If it is, then i would look at the clutch. If he used a cheap taiwan clutch and was hard on it, 1.5 years of abuse will certainly wear it down faster than normal.
Toyotero
Apr 26, 2024 08:27 AM
run4life78745
May 17, 2009 04:08 PM
