96 runner with sagging rear coils
Old Sep 19, 2006 | 11:26 AM
90vetteman's Avatar
You might want to try a set of Airlift air bags. They mount inside of the coils and you can adjust the air pressure for different loads.
Old Sep 19, 2006 | 02:40 PM
yotarunner96's Avatar
Originally Posted by MTL_4runner
Only 96-98's
.....but those springs are not as tall as the 99 coils so you'll begin sagging again almost immedaitely.
well i have a 96, so i might try to get a brand new set for free. i think they would be better than what i have on there now, and i wouldnt be spending any money either
Old Sep 19, 2006 | 02:51 PM
MTL_4runner's Avatar
If it's free, I say go for it.....just because it didn't work for me doesn't mean you won't like them. I was just sharing what happened when I did mine. If they sag you can also use the helper airbags to level off the rear.
Old Sep 20, 2006 | 12:26 PM
well i just went to the dealership to see about the recall on my springs but i guess the previous owner had it done right before they sold it. oh well
Old Sep 20, 2006 | 12:40 PM
  #25
cackalak han's Avatar
You should tell them that obviously, the "new" springs did not resolve the issue. Worth a shot.
Old Sep 20, 2006 | 02:31 PM
  #26
Skrillah's Avatar
yeah thats bull...
Old Sep 20, 2006 | 03:25 PM
  #27
so do you think that even though they were replaced in 2002, that they should replace them again because of sagging again?
Old Sep 21, 2006 | 04:42 PM
  #28
mpavolka's Avatar
They should replace them for sure, not that it is worth anything but if cheverolet ever replaces anything for warranty they guarentee it for life. Also for reference I have a 99' SR5 and I just replaced the springs because they were sagging so if you buy springs go with a new set. I put Downey 2" in the rear and 4runner barely sits higher in the rear. However they cost about $200. The stock shocks fit fine but they were not dampened enough for the higher spring rate. The back end became a pogo stick, so if you have worn shocks you will probably be buying those as well.
Old Sep 21, 2006 | 05:26 PM
  #29
Elton's Avatar
Originally Posted by p nut
Or you can go to your Toyota dealership, since the rear coils are on recall. I just had mine changed out. That will be your cheapest solution. But call ahead first to make sure your rig qualifies.
hmm i didint know there was a recall ill have to swing buy the dealership and ask
Old Sep 21, 2006 | 05:33 PM
  #30
That's not the way Toyota works anyway....once your VIN's been cleared of the recall, you're SOL.
......unless maybe you can find a sympathetic dealership to fight on your behalf.
voiddweller
19
May 2, 2016 09:10 PM
stav
Jul 7, 2015 07:57 PM
cchinny
Jun 25, 2015 08:11 PM
chbarnha
Jun 18, 2015 10:23 AM
Luke
Aug 15, 2008 02:50 PM
