96' 4 Runner Fuel Guage Wierdness
Old Oct 7, 2012 | 01:42 PM
Gregs94Toy's Avatar
Question 96' 4 Runner Fuel Guage Wierdness
Sorry if this has been rehashed, I couldn't find any threads describing exactly what mine is doing. Well, by 38-45 miles on the trip meter after topping off the needle drops down to 3/4 tank or so then slowly moves back up. Next, with closer to 60-75 miles on the trip meter it slugs down to half and hovers.
I just just bought this thing used last week, so just learning it's quirks. I know my old 97' 4 Runner it would go about 65 miles til the needle would move off of full after a top off and never bounce around like this one is doing and reading incorrectly.
My question is: Will the low fuel light eventually come on after the needle has been showing E for awhile (that is, if it's independant of the gauge itself and reflects the True gas level). I see that it'll show nearly Empty for awhile if the gauge reads "lower" than it actually is...just don't want to run out an hopefully see the low fuel light. AND, is there a TSB for a 96' for the fuel gauge not reading correctly? Thanks
Old Oct 8, 2012 | 04:36 AM
Texas_Ace's Avatar
My gauge is wonky too, it is a common problem.
the light always comes on at the same point from my experience, just under the lower hash mark.
Sometimes I can get to zero on the gauge and it runs out, others I can go another 40miles under the bottom of the gauge.
My driving varies so much using mileage doesn't really work for me. I will generally just fill up when it gets to 1/4 tank. If I have enough money I don't usually let my cars get below 1/2 a tank because it is not good for the fuel pump.
Old Oct 8, 2012 | 04:50 AM
Gregs94Toy's Avatar
Will Toyota take care of the TSB if I bring it in? or was it for only certain years?
Old Oct 8, 2012 | 05:52 AM
Texas_Ace's Avatar
Don't know if there is a TSB, just know it is a common problem.
Old Oct 8, 2012 | 11:20 AM
TheDurk's Avatar
There was a TSB for '99 and '00, but even then it was specific production dates and VIN ranges (not including mine, which still works fine). You can access it here, thanks to Raydouble at ih8mud : https://sites.google.com/site/raydou...edirects=0&d=1 You must be signed into Google to download the TSB.
I'd say the OP's problem is a bum sending unit.
Old Oct 8, 2012 | 12:54 PM
Texas_Ace's Avatar
Doesn't look like that TSB is still covered under warranty and that will cost a LOT to fix.
I think my truck falls into that range but kinda hard to tell.
Old Oct 8, 2012 | 05:37 PM
Gregs94Toy's Avatar
Called the "Stealer" this morning and they quoted $500 a piece to fix either the gauge or the sending unit, and said that is more likely a sending unit issue. Anyone around L.A. or O.C. California want to make a couple hundred bones?
Poppie51
Jun 4, 2020 09:47 AM
the1998sr5
Oct 19, 2016 12:48 PM
CJ94yota
Jul 3, 2015 10:14 PM
OffroadRalph
Jul 2, 2015 07:28 PM
