96-02 4Runner Service Manual Online
Old Dec 4, 2020 | 09:51 AM
Malcolm99's Avatar
This is always handy.
Old Mar 8, 2021 | 02:56 AM
alabamatoy's Avatar
This does not match my '99 4Runner. This one shows a throttle control monitor device under the TPS on the throttle body which my 99 does not have. Mine (which I bought new, so its not been modified) has an auxilliary air valve under the throttle body, which this manual does not even show. I tried to find some confirmation of the fact that the manual is for a 96-02 4Runner, but was not able to do so. While I sincerely appreciate the effort someone went to in posting the documents, they appear to be wrong in some very critical areas.
Old Mar 8, 2021 | 08:52 AM
Malcolm99's Avatar
It is for the 2001-02 4R, but the only difference is the Throttle body and the brake system for Trac and VSC really, are you looking for anything 96-2000 specific? I might be able to dig it up. The vacuum operated throttle stepper and IAC is adjusted and set from factory so you shouldn't have to mess with them, but you can clean and test the IAC, Timmy the tool man has a decent vid on that.
Old Dec 10, 2023 | 03:46 PM
Ocean’sRunner's Avatar
1996-2002 Toyota 4runner Service Repair Maintenance Manual Fsm + Wiring Electrical Manual
Here's one that I use. It's 17.99 but is definitely worth it.
Old Jan 2, 2024 | 08:32 AM
  #25
twntyfive2life's Avatar
Don't support someone reselling a factory manual PDF, you can download the same thing from here- https://www.tundrasolutions.com/thre...manual.151935/
Emtsrus
Apr 3, 2016 12:05 PM
twistemm
Sep 12, 2012 10:23 AM
twa318
Dec 4, 2010 11:49 AM
ads86runner
Sep 18, 2006 04:01 PM
Localmotion
Jul 26, 2004 09:53 PM
