92 4x4 xtra cab using oil...
My 92 4x4 3.0 V6 has 169K and uses(no leaks) about 1 qt of oil every 3K(OCI w/ GTX 10w30). I believe it stems from running hot back at about 80K due to cracked head gaskets that were recalled. Otherwise it's still runs great and has no other issues. Will running a heavier weight slow the consumption (perhaps a 15w40)? Thanks!
I use 10w40 in mine, I had too much valve clatter and leaking around the valve cover seals with 10w30. if it doesn't get much below freezing often where you live, 15w40 should work fine.
what brand 15w40 were you lookin at? make sure that it's also rated SL for gas engines, as some are only for diesel engines.
Good question. My 92 xcab 3.0, with 173,000 also burns oil. I'm not sure at what rate but every time I check it I have to had oil. I also have valve noise. Will running a heavier oil quiten them?
Crap man, my 91 uses about twice that much oil. I wouldn't wory about it. Once you have a big white could of smoke coming out the exsost untill it warms up, then you should wory. My dad drove a honda that did that to the point that it ran on 90w gear oil before it finally stoped going compleetly but that's another story.....
jasonty
41
Dec 23, 2018 01:00 PM
Steezy96yota
Jul 6, 2015 10:00 AM
