91 4runner headache
Old Jul 27, 2005 | 04:14 AM
dougm395's Avatar
Unhappy 91 4runner headache
i have a 1991 toyota 4runner 3vze that wants to choke down when i press the brake.it idles like a dream,when driving down the road coming to a stop press the brake and it chokes down.also this morning i noticed that at speeds above 35 when i take my fott off the gas it does the same thing. please help
Old Jul 27, 2005 | 05:28 AM
2ToyGuy's Avatar
What do you mean by "choke down"? Does it slow the idle to shutdown levels? I'm just trying to make sure I understand what you mean before I make a guess...er...I mean try and give advice
Old Jul 27, 2005 | 07:53 AM
dougm395's Avatar
it boggs down rpms fluctuate and then it cuts off
Old Jul 27, 2005 | 08:33 AM
leiniesred's Avatar
Idle speed too high.
The 3vze computer features a nifty 100% fuel cut when you have the brakes on and the RPM is over about 1500. Saves you gas and stuff. But, when the idle is set too high, the fuel cut kicks in and out as you slow down or when the brakes are on at a stop light. Sucks, huh? Good thing it is an easy fix!
Old Jul 27, 2005 | 09:13 AM
dougm395's Avatar
ok i idled it down to 700 rpm and problem still exists what next fuel filter maybe.
Old Jul 27, 2005 | 09:20 AM
DudeBud's Avatar
mine has done it for a few years havent figured it out yet fuel filter didn't change anything
Old Jul 27, 2005 | 09:21 AM
94x4's Avatar
Guest
Allow me to reiterate my post in the Maintenance thread and/or redirect you there: Throttle Position Sensor
Same thing goes for you DudeBud.
Old Jul 27, 2005 | 09:39 AM
DudeBud's Avatar
so you think its the TPS wouldn't it be giving a CEL if it was?
Old Jul 27, 2005 | 09:51 AM
94x4's Avatar
Guest
Depends and, not necessarily.
It does'nt hurt to check it out and you may be able to do it with the diagnostic check procedure.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 16, 2015 06:16 PM
