91 4runner body lift?
hey. im new to the forum, so please bear with me....
i have a 91 4runner, completely stock. i want to fit some 33" tires underneath it. what is the cheapest lift i can get to do that? i considered a body lift, but the thing is, it seems that you cant put a body lift on the automatic transmission trucks. im not really going to be offroading or anything, i am really just looking at cost right now. (i am very cheap) any help is appreciated.....
(PS: is HTML available on these forums???)
Co-Founder/Administrator
Hello, and welcome to the forums here.
Try a search, and you will see that you can fit 33" tires with a 1" Roger Brown body lift, and Downey coils with the Downey spacer in the rear, and your T bars up front cranked a bit.
Plus a little fender well massaging up front.
Roger Brown you can contact from our Vendor section.
He is listed as 4Crawler.
You can put on the 1" body lift with an automatic with no problems.
Quite a few have done that already.
I have 31s on mine, but can easily run 32s with just the Downey coils back aft, and the SAW T bars up front cranked.
http://www.pnw4runners.net/runs/91402/241024.jpg
http://www.pnw4runners.net/runs/8302/221024.jpg
http://www.pnw4runners.net/runs/8302/61024.jpg
http://www.pnw4runners.net/runs/11_9_02/42.jpg
We have HTML turned off here for security reasons.
You can add pics using the UBB command if you have your pics on the 'Net somewhere.
You can try out the Wabfab 1" for $99. http://wabfab.org/products/bodylifts/bodylifts.htm. I'm not sure your gonna be able to fit 33s but this is the only height available for automatics (from what research i've done).
Jun 1, 2021 01:51 PM
skoti89
Jul 6, 2015 07:45 PM
1991, 4runner, 909192939495, 91, body, cheap, cheapest, fourrunner, inch, lift, lifts, runner, suspension, tires, yotatech
