'91 3vz head repair - anything else?
Old Feb 16, 2004 | 11:27 AM
dafried's Avatar
searched and found lots of good info, but I want to be sure, since my engine is already apart.
My intention is to repair/replace as much as sensible. I plan to:
1) Have the heads machined and exhaust valves replaced and valves adjusted - all by local shop.
2) Replace Timing Belt and related parts using NWOR Timing Set $137
3) Replace knock sensor wire - do I need to replace knock sensor?
4) Replace head bolts NWOR $50
5) Replace gaskets as provided in NWOR Overhaul gasket set $203
6) Replace PCV Valve, thermostat and thermostat gasket
7) Replace all drive belts and radiator hoses
8) Send Fuel injectors out for cleaning and use NWOR Fuel Injector Overhaul Kit - Gaskets $39
Any opinions on this? I appreciate any feedback, as I may be missing something or doing more than needed.
Thanks,
David
Old Feb 16, 2004 | 11:30 AM
Dr. Zhivago's Avatar
Away
I would avoid NWOR like the plague and find another source for your parts.
Some information: https://www.yotatech.com/forums/show...&threadid=9002
There are MANY threads in MANY forums with people who have had similar experiences with NWOR.
Good luck with your project.
Peace.
G
Old Feb 16, 2004 | 02:24 PM
85runner's Avatar
You could try www.engnbldr.com for toy parts...not sure if he has them for the 6's....
bigjstang
Jun 2, 2025 03:56 PM
kgcwb44
Jan 29, 2023 10:02 AM
mdev126
Oct 4, 2015 04:48 AM
Koolbananass
Aug 12, 2015 01:59 AM
