86 std. cab w/ carb
Old Oct 2, 2002 | 02:09 PM
cvlighthouse's Avatar
86 std. cab w/ carb
I have a 86 toy truck with a 22R carb. It has a 4" trailmaster lift with 94 running gear. Right now it is out of service due to a blown head (4th time) and abused clutch. I've been offered
$ 1,000 by friends. Should I keep it and fix it, or fix it and then sell it, Or should I sell it as is? What's it worth?
Old Oct 2, 2002 | 02:14 PM
AZTOY's Avatar
fix it
Fix the truck do a sas swap and turn it to a trail truck . leave the 4 runner for work!
Old Oct 3, 2002 | 03:57 PM
jx94148's Avatar
By blown head do you mean blown head gasket? If that's the case and it has happened 4 times you probably have a warped block or head or both and the motor is not worth anything. Take the $1000 you were offered and get an '85 or older straight axle rig to build.
Old Oct 4, 2002 | 07:32 AM
ya im pretty sure that the block is shot. I have put in a new head and the gasket still leaks after about 20,000 miles. Did i mention when it is running it doesn't pass smog.... I'll probably sell it. Too many great memories .. it's a sad day...
priest16
15
Aug 6, 2015 07:43 AM
yotanothing
Jan 25, 2011 05:13 PM
drew303
Jul 12, 2007 10:44 PM
Subaru4WD
Jun 28, 2007 03:34 PM
2d
Apr 18, 2006 01:09 PM
