85 4Runner Auto Trans - 4Low Thumping Noise in Drive Only
Old Dec 14, 2004 | 05:49 AM
pinemind's Avatar
All,
I had the unfortunate experience of waking up at 1:30 AM last night to a phone call from a friend who had sunk his giant F150 up to the bumpers in a giant puddle (lake). I take my 85 4Runner out there and hook up some chains to the front hook on my truck and his rear bumper. Long story short, I couldn't pull him out (after all, it's a 22re stock and it weighs probably 1/2 as much as his mud sunk F150).
Strangely enough, I used 4Low for the first time since I bought the truck. In reverse it was great, really grippy. However, when I shifted to Drive in 4Low, the right front wheel area would make a 'clunk' or 'thump' noise upon a full rotation.
Is there something I'm missing here in shifting from reverse to drive in 4Low?
Better yet, what could be broken?
Regards,
Justin
Old Dec 14, 2004 | 06:47 AM
yotafreakshow's Avatar
I would get under there and check all of the bolts that hold anything at all.
Springs, shackles, ubolts, driveshafts, tranny mounts, crossmember, lugnuts...you get the idea. Put a wrench on everything.
Do you still get power at both front wheels in D?
Old Dec 14, 2004 | 09:24 AM
pinemind's Avatar
That I'm not too sure about. Here's the thing. I don't see it as a loose bolt problem because in every other setting (2H and 4H) I get a smooth ride in Drive and Reverse. It's only 4Low - Drive where I get the noise. I guess it could have something to do with my hub not engaging on that side? But then again, how would that explain the smooth ride in 4High?
hmm. . . i'm not experienced enough yet to diagnose this one
Justin
Old Dec 14, 2004 | 03:14 PM
Sounds like a potential transfer case issue. I'd find a safe, open area and put'er in 4L, and drive slowly with my head out the window or the door open to try and isolate the source of the noise.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
vasinvictor
Jan 20, 2016 12:39 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Outsane
Jul 15, 2015 05:01 AM
BLRobertson
3.4 Swaps
Jul 10, 2015 04:27 AM
