84 5speed leaking
Old May 13, 2003 | 08:33 PM
eroc1313's Avatar
84 5speed leaking
ihave a 84 xtra cab with 22re and the tranny leaks a little.if it is parked for a couple hours a drop or 2 will be on the ground.it looks to be coming from the seal on top of tranny with the 4 or five 12 mm bolts holding on a plate that is just below the 4 that hold on the gear shifter lever which has 10mm bolts holding it on .How tight should the 12mm bolts be on that plate?have u ever seen this plate leak gear oil?its difficult to see if it is the place that is leaking.I tightened the 12 mm bolts and cleaned the tranny off,refilled up to the hole and i checked it periodically for a day or two and i didnt see any more fluid.I figured i fixed it and a week later it was dropping fluid again.apparently the leak isnt that bad.when i wiggled the plate in question it looked to have some gear oil coming out of the seal.It is a black flat one .I tightened the plates bolts in questionbefore i cleaned it and used a 3/8 ratchet and snugged em.
Old May 14, 2003 | 06:33 AM
rimpainter.com's Avatar
Pics man, pics!
You sure its gear oil? Did you smell it?
Old May 14, 2003 | 08:18 AM
eroc1313's Avatar
its the tranny
yes its the tranny gear oil for sure.
Old May 14, 2003 | 10:12 AM
Well, its most likely the input/output shaft seal. Which, if you keep the tranny fluid "full" shouldnt pose much of a problem. We had the same problem on our old 92 Maxima, and just kept our eye on it.
Eventually it will need to be replaced, but you will have to pull the tranny.
Old May 14, 2003 | 05:34 PM
eroc1313's Avatar
i think i fixed it
gear oil was leaking from the plate that bolts on the gear shifter.It is the one with the 4 10mm bolts.I took the plate off and noticed some oil had been leaking out of it.It doesnt have a seal it just mates metal to metal.i put some rtv and that should have taken care of it.Thanks for the help!!
Old May 15, 2003 | 06:32 AM
Glad you found it! And it appears it was an easy fix.
Old May 15, 2003 | 07:45 AM
eroc1313's Avatar
thanks
it was very easy and i would have found it sooner if i would have just looked better the first time
ghostmoney
Jan 28, 2018 11:42 AM
Peevedkitten
11
Aug 31, 2015 06:57 PM
scooba
Aug 25, 2015 09:49 AM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
HRDC0R19
Jul 5, 2015 06:43 PM
