82 22R, thrust bearings destroyed
Old Oct 26, 2005 | 10:39 AM
Yoda's Avatar
82 20R, thrust bearings destroyed
Working on a 82 20R. Was changing the clutch (neighbors truck) and noticed a lot of end play in the crankshaft (moves front/back about 1/4"). Dropped the pan and found the thrust bearings destryed and laying in the pan
The rear of middle main cap, the block and the crank are all garfed up. I assume it was initially caused by a driver holding the clutch in at stops.
Any cheap fix/workarounds for this? A suggestion was given to JB weld the bearings in place so they won't fall out.
Old Oct 26, 2005 | 11:59 AM
kyle_22r's Avatar
i think for the most part you're screwed if the thrust washers ate the block up much...
i've heard the earlier engines liked to eat thrust washers, nobody's ever given me an explanation. maybe quality of the washer itself?
Old Oct 26, 2005 | 01:32 PM
Yoda's Avatar
Yeah, it looks like the block and the crank have been rubbing for a while
Old Oct 28, 2005 | 08:33 PM
84sr5yoty's Avatar
"I've heard the earlier engines liked to eat thrust washers, nobody's ever given me an explanation. maybe quality of the washer itself?"
When you say "earlier engines," what years are you refering to? I hope 84 isn't included
Old Oct 29, 2005 | 12:16 AM
kyle_22r's Avatar
'84 and older, probably to '75.
i wouldn't sweat it, i've never personally known anybody whose engine dumped the thrust washers...
Old Oct 29, 2005 | 09:24 AM
Yoda's Avatar
Hey, just reading my post........It is really a 20R
The 22RE engines had the same style thrust bearings. They are just held in by the close tolerace fit of the crank to the block. It they wear (maybe .030 to .040 thou) they could fall out. then the fun begins
Old Dec 17, 2007 | 03:05 PM
jpoetzs's Avatar
What did you end up doing with this engine? I'm dealing with a similar issue and really don't want to put a new engine in as the current one was rebuilt 12,000 miles ago. My only conclusion was to replace the entire engine since the no. 3 bearing cap and block were "ground" down to the extent that there is no way a thrust washer will stay in place.
smthwsn357
May 1, 2024 07:28 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
G-off
Dec 29, 2015 12:44 PM
shalom
Sep 8, 2015 10:02 PM
justdifferentials
Sep 5, 2015 06:52 PM
