5VZ + TRD Supercharger, cant stop the ping?????
Old May 10, 2009 | 08:39 PM
  #41
ozziesironmanoffroad's Avatar
im sure this is a stuopd question (since im kidna drunk, (again... lol gi,mme a break im still celebratiun bein 21) and i didnt read the post's first page, what kind of gas u runnin? humor me a bit and run some 112 octane gas (if its in ur area). if u cant gedt it, put a little bit of alcohol in your gastank to increase the octane and see if the pinging stops.
Old May 10, 2009 | 08:45 PM
  #42
Texas_Ace's Avatar
Quite true, i am going to be doing this with my car since i am having ping problems with it. If it doesn't ping with race gas then it is indeed a tune problem, if it still pings with race gas then the problem is much deeper then a tune or a faluse signal.
Old May 11, 2009 | 06:29 PM
  #43
Froggy93's Avatar
sorry hit the wrong button
Old May 11, 2009 | 08:58 PM
  #44
okie81's Avatar
It doesn't make sense that changing the head gasket (compression ratio) would solve the aforementioned problem.....but....I could see that if there was some considerable buildup in the chamber, that would be a definate issue although from information I read, I'd guess it was a fuel mapping issue.
Old Apr 15, 2012 | 03:41 PM
  #45
03SR5's Avatar
Big blast from the past!!!
Ok so, in a nutshell:
The thicker gasket was fitted, the comp ratio lowered, truck was tuned, pinging was gone!!
A 2.1 pulley fitted, and again, ping still nowhere to be heard.
Happy days!
Aquamist WI was also fitted, not to fix anything, but just to cool the set up a little and provide some insurance on the stinking hot days we have here in Aus.
Truck has since been 'retired' from daily duties and gets wheeled once every couple of months. Looks like this now, love the thing!:
After all this time has passed, i feel that she needs a bit of TLC..
I'll be getting her back on the dyno for a retune, because its never been tuned since having the aquamist fitted.
But before i do i was curious to know what plugs i should be using.
To be completely honest i can't even remember whats in it at the moment. This thread says that they are 2 steps colder than the stockers. But this was done when we were scratching about to try and fix the pinging.
So what would be optimal given my set up?
5vz
TRD SC
2.1 pulley
3" exhaust
Aquamist WI
Standalone Engine management
Lowered Comp ratio
Thanks!!
Old Apr 30, 2012 | 07:34 PM
  #46
03SR5's Avatar
Anyone able to shed some light on what plugs i should be running??
Old Apr 30, 2012 | 08:08 PM
  #47
mokai's Avatar
I would recommend Denso IK22. They are the Iridium ones. Just put a set in my Taco with a new set of wires and they seem nice.
Old May 1, 2012 | 05:45 PM
  #48
03SR5's Avatar
Thanks for that Mokai!
Like I said, i cant remember, and am not home to be able to check what im running, so im curious to see!
Anyone else had any experience with mucking around with different plugs?
Old May 2, 2012 | 05:22 AM
  #49
Texas_Ace's Avatar
The IK22 are the standard supercharger plug, they will work fine.
I have used a few different types of plugs personally, They all work pretty similar. The biggest difference I have found is when gaping the plugs down I do get a boost in performance. I would not gap iridium plugs as the tip can break off (the IK are iridium).
So I have just been running the NGK bkr7e's for the last while gaped down to ~.028 (they open up quick, about 3k miles later they are already up to .031). These are a lot cheaper but also will not last as long. I happened to have some laying around from my MR2.
suppra87
Jul 15, 2021 05:15 PM
4.34runner88
Feb 7, 2016 02:24 AM
anniesball
Sep 5, 2015 08:45 AM
LJR
Sep 5, 2015 06:02 AM
moparbay
Sep 3, 2015 12:48 PM
