5sp won't go into gear
Old Dec 26, 2004 | 03:50 PM
rpeAMP's Avatar
Originally Posted by ken.vs.ryu
truck is hard to shift into 1st. i have to force it into 2nd, notchy, and then it will go into 1st but notchy. into reverese i would just grind my gears so i have to go into 1st first then rev.
-i'm gonna check tranny oil first.
hmm according to this its the synchro or the shifting key spring.
Same problem and thought it was the clutch due to this and other reasons. Got a new clutch and it still does this. One thing to check is downshifting. Any grinding when downshifting? My next move is new synchros.
Old Dec 26, 2004 | 03:52 PM
notoyos's Avatar
thats what i was thinking
Old Dec 26, 2004 | 03:59 PM
89macrunner's Avatar
why would this have anything to do with the syncros? if the syncros were bad there would be grinding when shifting to any other gear....if your syncros are bad you dont really need to get a new transmission you can just double clutch it all the tiome.....
Old Dec 26, 2004 | 04:16 PM
notoyos's Avatar
syncs can wear out in only one gear
Old Dec 26, 2004 | 06:25 PM
  #25
rpeAMP's Avatar
Double-clutching didn't help for me before my new clutch and doesn't make it any easier now with the new clutch...it sometimes makes it HARDER to shift.
Also, the 2nd gear synchro gets a ton of abuse because there's hardly any momentum when the car is between 1st and 2nd gear. It's practical to assume that this synchro can be bad especially on high mileage vehicles.
To be quite honest I am a living example of someone who doesn't know EXACTLY what's wrong here. I have the same symptoms as what's been described, so I installed a new clutch. Same problem, so I have to move on and assume that it's something other than the clutch causing the problem. Synchros are my next option as they logically should be. Will it fix the problem? More than likely, however if it doesn't, I move on to the next option.
Old Oct 11, 2005 | 10:09 PM
  #26
jimbo74's Avatar
my truck does it too...... i have learned to deal with it
Old Oct 12, 2005 | 10:10 AM
  #27
garrett1478's Avatar
jim, are you kidding? this threads almost a year old.
Old Oct 12, 2005 | 03:06 PM
  #28
msw0085's Avatar
bahahahaa
Old Oct 29, 2005 | 01:58 AM
  #29
bob200587's Avatar
well, since this has been brought up again. I was wondering if anybody has any ideas what's wrong with mine. I went out to go to Kroger earlier tonight, and I got in, and didn't have any clutch pressure, I let it warm up, still no, got out checked the resivoir on the master cylinder, it was full, theres no fluid leaking anywhere....But the clutch isn't doing anything, and it won't go into gear......I'd imagine the slave cylider was out again.....even tho I got a new one a few months ago, and another new one 7 months before that. I'm gonna get out and work on it when the sun comes up.....and it gets a little warmer. If the slave cylider doesn't seem to operate, would that mean it is bad for sure, or how else could I tell.
Tykiller1994
Aug 10, 2015 07:49 PM
jbandt
Aug 3, 2015 03:23 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
94yotaky
Jul 23, 2015 07:50 AM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
