5000 miles service
Old Mar 6, 2003 | 07:42 AM
2002 SportEdition's Avatar
5000 miles service
Hi everyone,
What do I need to do for the first 5000 miles service for my 02 4Runner? I got a dealer coupon for 5000/7500 miles service interval for $36.90, I just don't know what they will do to my rig.
Thanks,
Old Mar 6, 2003 | 08:27 AM
rimpainter.com's Avatar
The ONLY benefit I see in going to this type of dealer service is their ability to find problems covered under warranty.
In my opinion, you dont need to take it to the dealer unless you suspect there is a problem with the vehicle (I am assuming you do your own oil changes, etc).
The big question is, how much is the coupon for?
Old Mar 6, 2003 | 09:03 AM
RTdawgs's Avatar
5k service is prob only change oil, rotate tires, and check stuff.
Old Mar 6, 2003 | 09:26 AM
I don't know what is the regular price but with this coupon it stated $36.90. I'll have to call them to see what will they do.
Thanks,
Old Mar 6, 2003 | 09:29 AM
TDiddy's Avatar
This brings up another question I've always wondered about...
Alot of times it states that the warranty will be voided if you fail to keep up with the regular maintanence. Are dealers ever sticklers for that, or is that just another ploy to get to to spend your money with them? If you provide records receipts showing the work was done, is that good enough? Just curious.
Old Mar 6, 2003 | 10:26 AM
As of late, I have seen dealers jumping on warranty fixes. I dont know if it has to do with the economy, or what. Generally speaking, most dealers, but not all, will take things on a case by case basis. If you dont change your oil in 60K miles, and you complain of a sludge problem, they probably wont cover you.
Service advisers play a pretty big part too. I have had some good ones, and some real jerks.
Old Mar 7, 2003 | 04:51 PM
Doublepump's Avatar
The manual says what needs to be done at what intervals. As was said, probably just oil, rotate tires, inspection.
You are not required to have the dealer perform any regular maintenance or service to keep your warranty. And you really don't need to save receipts, but it is better. Just keep a log of what was done, the miles and the date. Follow the recommeded interval as stated in the owners manual. However, if you do something yourself and do it wrong, then that is not covered. I also keep all receipts for everything just to be on the safe side of things.
colasurdo
Jan 11, 2026 08:10 AM
Eggslinger
Jun 8, 2019 03:32 PM
icentropy
Jul 13, 2015 10:57 AM
Poncho0206
Jul 10, 2015 06:21 PM
Vargntucson
Jul 4, 2015 12:15 PM
