5 1/4" backspacing work for 96 4x4 with 32x11.5?
Old Aug 30, 2004 | 08:51 PM
baileymoto's Avatar
and a 3-4" lift with glass fenders
or would this not look right?
Old Aug 31, 2004 | 01:49 AM
josh's Avatar
zesty
They would be tucked in a LOT and you would have issues with rubbing the suspension and frame. Go with something like 3.75 or 4. Also, the glass fenders only give you extra clearance on compression, not in the pinch weld area where you will most likely be rubbing.
Old Sep 1, 2004 | 04:18 AM
jacksonpt's Avatar
Senior Member
90% sure it WON'T work. My old 32/11.5-15s on stock rims just barely cleared the stock upper a-arms. You tuck the wheels in closer with 5" BS and they are going to rub for sure - and it would be a constant rubbing, not just at turn or flex.
Old Sep 1, 2004 | 05:34 AM
dragr1's Avatar
Nope. You need to be looking around 3.5 to 3.75" backspacing.
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
