4x4 vibrations
Old Dec 29, 2010 | 12:44 PM
exrunner's Avatar
4x4 vibrations
Ok, here goes. When I press the 4x4 button, (AWD) I get a noticeable vibration from the front. Feels like a bad u-joint/bearing. Dont really notice it below 25 mph. Sounds like a classic bad u-joint, right? So I had the front and rear drivelines checked and balanced. No change. replaced the front axles. No change. Front end is tight, the front and rear diffs have new gears, lockers and bearings. Ideas?
Old Dec 29, 2010 | 12:48 PM
85gijunk4x4's Avatar
sounds like a misalgined ring and pinion in the front diff.
also you can never really trust anybody so you may have a bad ujoint or out of balance driveshafts and u-joints.
dont take my word for it though, lets wait and see what the others have to say
Old Jan 3, 2011 | 04:54 PM
exrunner's Avatar
the front driveline went to two different shops, same conclusion. Any other ideas before I yank the front diff out?
Old Jan 4, 2011 | 08:27 AM
rideexileex's Avatar
Was thinkin same thing as a bad front gear install... was this present before the new gears/lockers? If not, it gives a very good idea of what the problem may be
My old rear U-Joint actually sounded worse at low speeds
Old Jan 4, 2011 | 09:22 AM
dropzone's Avatar
Fossilized
are you engaging 4WD on dry pavement?
if this just started after the install than sounds like a install issue to me.
F/R ARBs-i have locker envy
Old Jan 5, 2011 | 04:12 PM
exrunner's Avatar
Thanks for the suggestions. Looks like Im going to have to get the front diff looked at.
It didnt do this before the install, that I remember. Ill update when I get it looked at.
mussy01
Dec 13, 2016 08:20 PM
redneck17
Aug 5, 2015 10:03 AM
defrag4
Jul 31, 2015 10:50 AM
PopsDad1
Jul 30, 2015 02:21 PM
pyramid
Jul 29, 2015 06:53 AM
