4x4 Shifting
Old Sep 3, 2003 | 06:03 PM
Fink's Avatar
4x4 Shifting
This question just popped into my head, is it OK to shift into 4H from 2WD while moving? I'm pretty sure that going from 4H to 4L is bad while moving (should I be in neutral when doing it?)
I know that sounds like a nOOb question but...ok so yeah it is.
Fink
Old Sep 3, 2003 | 06:04 PM
rimpainter.com's Avatar
Everything you said was correct Chris. It is ok to go 2 --> 4HI or vice versa.
Old Sep 3, 2003 | 06:08 PM
Fink's Avatar
OK. Do I have to be in neutral when going from 4H-4L and back?
Is there a certain speed where its bad to shift from 2-4H?
Thanks man.
Fink
Old Sep 3, 2003 | 06:20 PM
Yeah, N for 4HI to 4LO. You can shift on the fly if you are under 50MPH from 2 to 4HI or vice versa. I also slow way down.
Old Sep 4, 2003 | 12:19 AM
UKMyers's Avatar
Below 50 mph for 2hi to 4hi... personally I slow way down.. and completely stop with clutch in for 4hi to 4low. No need to goto neutral. Or if all else fails look up.. complete instructions are on the visor
Old Sep 4, 2003 | 04:17 AM
4RunnerFever's Avatar
I checked my owners manual for a 1998 4Runner and with an automatic on a 3rd gen you definitely have to put the transmisson in neutral, shift into 4lo, and then put the transmission back into the gear you want.
I seem to recall this was the same when I had a 1995 4Runner
Hope this helps
Old Sep 4, 2003 | 12:10 PM
AgRunner06's Avatar
Post
Under 50 mph from 2HI to 4HI. If I remember right it is under 18 mph from 4HI to 4LO, but don't quote me on that. I have yet to need 4LO but if I did I would just stop and then shift it. Check your visor or owners manual. Both will tell you what to do.
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
Tykiller1994
Aug 10, 2015 07:49 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
crashburnoveride
Jul 10, 2015 06:39 AM
