4WD tire size question
Yesterday it rained and after fishtailing at an intersection from my 80% used rear tires I threw her into 4WD. when I got to my destinatinon and put the truck in park I could hear the transmission kick, as well as the frame of the truck.
Okay I understand 4WD systems like to bind, but then I noticed that the rear tires are slightly larger than my front (bought the truck 5 mos ago, never gave it any thoguht.) This leads me to believe that due to the difference in tire size, the front and rear wheels are moving at different sppeds, which prolly isnt good for a synchronized drive train. Therefore causing the excessive binding.
Am I right?
Am I right?
Yep.
On the newer rigs with open/locking diff's in the xfer case, it's not quite such a big deal, but on yours, the tires need to be pretty close in size. Any time the drivetrain can build up a differential in torque because of different tire sizes, use on pavement, etc, it's a potential problem. Maybe it won't bite you, maybe it will...
Ok, a couple things.
Different tires will cause the axles to spin at different rates and cause bind in 4wd.
Different gearsets in the diffs will do the same thing.
4x4 on the pavement is gonna caus ebind, especially when turning.
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
