4Runner overheating
Old Jan 30, 2003 | 02:55 AM
Dez's Avatar
Dez
Angry 4Runner overheating
Gday, ive been having a few problems with my truck when travelling up hills or when it its under load. After a while under load it starts to overheat, if i ease off the temp falls back to normal. I have had my radiator overhauled and the water pump seems to be running fine. It is not using or losing any water externally and i am stuck for ideas to fix the problem. Can anyone help??????
Old Jan 30, 2003 | 03:27 AM
UKMyers's Avatar
Please provide some details about your rig!
Old Jan 30, 2003 | 06:30 AM
Victor's Avatar
Change your thermostat. If that doesn't do it then assume the water pump isn't ok. At this point though I'd recommend you have a mechanic pressure test the system - perhaps you have the beginnings of a head gasket failure?
Old Jan 30, 2003 | 02:29 PM
I had the same problem on my 90' V6. I changed the Radiator and Thermostat and it went away. Good Luck!
Old Jan 30, 2003 | 07:15 PM
Fahrenheit 451's Avatar
Have you checked out the catalytic converter? A plugged up one will make the motor run hot under a load.
Old Feb 9, 2003 | 02:33 PM
Dez's Avatar
Dez
still overheating
Thankyou for all your suggestions so far but my overheating problem still exists.
My 4Runner is a 1987 LN61 model, with a 2.4 litre diesel and an after market turbo installed. So far i have replaced the thermostat, have to radiator overhauled, checked the water pump and had the cooling system pressure tested. None of these seem to be the problem, but the overheating up hills still continues.
Any ideas would be greatly appreciated.
Cheers, Dez.
Old Feb 9, 2003 | 02:49 PM
Victor's Avatar
Does this turbo have an intercooler and where is it? Just wondering if you are getting excessive intake temps which are overheating your engine under sustained loads. I've heard of other turbo diesels doing this - my stock VW Jetta TDi is somewhat prone to this because of the very high boost pressures - most of the people experiencing this are doing it at high altitude under full throttle to near full throttle. Just a suggestion.
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Rkellerman
Jul 12, 2015 08:42 AM
Avenged
Jul 9, 2015 07:55 AM
