4Cawler 3" BL help/options....anyone who else has this setup....
Old Jan 12, 2008 | 09:03 AM
4Runner4Trail's Avatar
Post 4Cawler 3" BL help/options....anyone who else has this setup....
Hey guys. Getting a 3" BL from 4Crawler b/c I'm tired of my 305 33's rubbing the wheel wells and rear bumper. I already have the OME 2.5-3" coil lift but thats not enough I've found out. Anyways, I know I'm going to have to extend my brake lines, etc., but what else should I buy when I get this lift? My main concern right now are my levers. Its an AUTO so do i need get an extension for my shifter and the 4WD lever? I am going to get the stainless option, etc.
Just wondering who else has done the 3" BL and what exactly their setup is and what they did/wish they did...
Thanks...
Old Jan 12, 2008 | 10:35 AM
drafn's Avatar
i did a 1.5 BL and had to go back and order the 2 inch 4wrd lever extender
Old Jan 13, 2008 | 02:27 PM
ARB4Runner's Avatar
the only thing you will need to buy is the 4wd lever ext. you can adj. the auto trani underneath. and maybe a stearing shaft extension if the kit does not include it. that is the exact setup i have on mine. the only time it rubs is when you flex really hard and turn.
Old Jan 14, 2008 | 12:14 PM
ToyoRunner94's Avatar
why are you going for a 3in BL? you'll be pushing 6in of lift. i would think that will make the truck a little to tipsy for comfort. i can't imagine you need 3 more inches to clear your 305's. why not stay on the safe side and get a 2in BL?
Old Jan 15, 2008 | 12:38 PM
hey all. I ended up getting the 2" BL. Since the 4Runner is still my DD i decided to keep it a 'little' more mild. Anyways, I figure I can used the extra $100 or what ever and put it into a bumper or gears or something. Will take pics when I get it all put on.....
Thanks for all the replies BTW!
Derek
Old Jan 15, 2008 | 03:56 PM
boxer0987's Avatar
a
I was wandering if I have a manual transmission and want to do a 2 inch body lift what extra will I need. Will I need an extension for my 4wd and my gear shifter. Will I have to extend my brake lines. 97 4runner. Thanks.
Old Jan 30, 2009 | 11:14 AM
chuckdeez's Avatar
Derek
wondering what you did with your t case shifter when you did the body lift/ i also have an auto and it has the push button 2/4. was thinking about toytec 3" and 4crawler 2-3 inch BL
FJHammerHead
Jul 12, 2014 10:21 AM
nix84yota
Jul 4, 2013 08:55 PM
sicnick
Feb 15, 2011 03:30 PM
Al's Chop Shop
Jun 26, 2008 01:20 PM
91 4Runner
Feb 13, 2007 01:42 AM
