3vze Valve Adjustment
Old Nov 4, 2004 | 10:57 AM
whays's Avatar
Has anyone here adjusted their own valves on a 3vze. I see there are a couple of SST's needed. HAs anyone figured out a way to do it without the SST. Any feedback would be great
Thanks
Old Nov 4, 2004 | 09:05 PM
Big blue truck's Avatar
You can measure the clearance of all valves. Determine the shim thickness then remove the cams to install the new shims then reinstall the cams . If you are going that far I would install some performance cams.
Good luck.
Old Nov 5, 2004 | 03:47 AM
HondaTec521's Avatar
But using the forty dollar tool is way faster than yankin cams.And you only need the tool to change the shims.If they are within spec,no tool needed.I only had one that was off-ex #6.The hardest one to reshim even with the tool.
Blamalam
Mar 12, 2022 07:34 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
razorman8669
Jul 12, 2015 12:13 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
