3vze perfomance?
Old Jan 27, 2005 | 09:22 AM
kev93p-up's Avatar
3vze perfomance?
It's about time to pull off the heads on my '93 v-6 for some t.l.c. I'm planning on going back with some headers and new exhaust, but wondered if there was anything else i can do to the heads (porting, cams, ect...) to get more power outta the 3.0. The only thing that's not stock is the intake pipe I built, and a modded air box. Also, who makes good headers for a reasonable price?
Old Jan 27, 2005 | 09:35 AM
95ToyotaPU007's Avatar
If you can, coat all the components that make up the combustion chamber with ceramic. It is fairly expensive though. I had it done on my Ford 351W and noticed an increase in fuel mileage and hp. And no I don't have deep pockets. A friend of mine was learning how to do this at an automotive school and I suggested my engine to be the guinea pig. The only thing it costed me was time to pull and remount the motor. The motor has been running smooth for 45K miles so far.
I think Doug Thorley makes some good hedders.
Old Jan 27, 2005 | 09:41 AM
TRunner's Avatar
The one thing I reqret NOT doing when I got my heads done was going with oversized valves. I did not find them until I got my heads back from the machine shop and I was broke by then. At the time (summer 2004) I found them real cheap on ebay, but I cannot seem to find them now. Maybe someone else will be able to help you out there, but if you are getting your heads machined do not pass this up as it will give you more power for just a few dollars more.
Old Jan 27, 2005 | 09:42 AM
Vtec_Killer's Avatar
I had a pain of a time looking for mods for the 3VZE engine. The most stuff I could find were the parts from Downey Toyota. If you do a search in Google for Downey Toyota, you should be able to get to their web site. Everything from intake all the way out to suspension components.
I'm sure we'll here of other(better?) suggestions here.
Old Jan 27, 2005 | 09:44 AM
Racer944's Avatar
Something we do with the engines we race with is hone the cyl. walls. this process is pretty cool because you impregnate the walls with silicone and then hone them out with a paste that removes aluminum, and not silicone, so it provides your pistons a layer of glass to move on. This treatment has become completely necessary, when we start bringing up compression and upping the stress. I'm not sure if this is possible on a Toy engine, as I don't know what the block is made of. I'm not even sure if this is just a thing we can do locally or if this is wide spread, but everyone in our region goes for this treatment.
Old Jan 27, 2005 | 10:52 AM
kev93p-up's Avatar
I don't plan on going any furtherdown than the heads. Besides the block is steel, thanks for the suggestion though. If i change the cams, or valve size, or both, do you think I will have sufficent fuel/air flow with stock throttle body and injectors with good exhaust?
Old Jan 27, 2005 | 11:24 AM
nunsa's Avatar
Get your heads ported and polished, One very important thing to do when you have the heads off a 3.0, Always, Always replace the knock sensor and wire, if not you'll get a code for a KS in awhile!
Get rid of that cross-over, it's the biggest power robber of them all. The bioggest problem w/the 3.0 is it can't breathe. Get some headers. Go with a freeflow cat and HP muffler and at least a 2 1/2" diam. exh. New injectors, have the valves ground or replaced w/os ones....!
Good Luck!
Old Jan 27, 2005 | 01:07 PM
4RunnerKid's Avatar
D.O.A. Racing
Old Jan 27, 2005 | 01:23 PM
rockota's Avatar
I ran DOA's heads on my ex's 94. Truck was fun to drive as long as the engine was above 3500RPM's... below that it was still a dog. Had I to do it over again, I would likely not put extra money into the 3.0. I'd of just driven until it died and put the $1500 towards a 3.4.
my 88 has headers, exhaust, DOA throttle body, K&N... It's not fast... at all.
Racer944's Avatar
Alright, too bad you can't do this honing technique, it's really improved our reliability. Also, honing is just what we call it, no clue if there is a more specific name of the process
Old Jan 27, 2005 | 01:40 PM
Bumpin' Yota's Avatar
do the 7mge AFM mod that cebby, parfuet, and myself are all independantly pioneering...LOL
Should give the 3vze 30% more air flow availability on the intake side. I have a loose exhaust anyhow so it should help.
MadMax48
Mar 3, 2020 10:33 AM
Kamaloha
Oct 16, 2015 05:13 PM
alexcarey
Oct 14, 2015 06:05 PM
Matthew Perez
Sep 28, 2015 05:43 PM
