3VZ-E Exhaust replacement
Old Nov 10, 2003 | 06:57 AM
Toyota_Tyler_SR5's Avatar
Hey guys, my exhaust is getting to the point to where it needs to be replaced.
My truck has the original OEM exhaust and I would like to open it up and make it 'burble' a little bit. What is a good combination for the 3vz-e engine? I'm not looking to put headers and a whole lot of extras on there that cost too much. I'm looking to have an exhaust note that is not too annoying yet when I get on it the exhaust will sound good.
I was thinking that I'd go with the stock diameter piping from the cat back to the muffler and then widen that up a little bit. I'd like to have dual exhaust, but that's not in my budget right now. SI/SO would be just fine with me.
Flowmaster? MagnaFlow? Glasspack? CherryBomb? Borla?
What's the consensus on your opinions?
Old Nov 10, 2003 | 08:29 AM
Highland Runner's Avatar
I've heard the Jardine cat-back is good. I think you can get it from truckperformance.com. I wouldn't open the exhaust up too much as it will kill your'e torque.
Old Nov 10, 2003 | 09:22 AM
CTB's Avatar
CTB
Check out the exhaust round-up page here on the forum - it will give you a ton of info.
Old Nov 11, 2003 | 05:48 AM
That's what I'm trying to avoid is killing my torque. The 3.slow is bad enough as it is and I would like to keep that low-end as much as possible, especially because I don't rev over 3500 RPM's.
I'm going to go check that exhaust page and see what there is for information there.
Thanks fellas.
Old Nov 11, 2003 | 07:46 AM
Waterboy's Avatar
I bought a flowmaster off of Ebay for $60 shipped to me. I've dealt with the seller a few times so I know he is a good seller. Then I payed a local muffler shop $100 to weld up 2.5" pipe cat back with the muffler. So I got my exhaust done for $160 and a little bit of time. I'm very happy with the rumble and if you don't want it as loud the seller has 50 series as well. I believe his name was Jon3x, just look up flowmaster on Ebay and you will find him. Good luck.
Old Nov 11, 2003 | 04:08 PM
martin's Avatar
I had the local exhaust shop put a high flow cat on mine with a normal muffler and it helped. A little less back pressure and still maintaining my torque. It sounds a little throaty, but not obnoxious.
Martin
Old Nov 12, 2003 | 04:20 AM
Thanks for the help guys. I was a lil apprehensive about going with Flowmaster as they are generally designed for V8's in mind. I had a Flowmaster on my Miata and it was great, but that's a totally different engine. I think that's what I'm going to go with is the Flowmaster 50 series.
Colington
Mar 8, 2020 09:51 AM
thefishguy77
Jul 30, 2015 10:59 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
hexrain
Jul 12, 2015 01:13 PM
Coreyr384
Jul 10, 2015 11:13 AM
