3rz computer reflash
Old Jun 9, 2010 | 05:40 PM
Savage1016's Avatar
i have been looking into modifying the 3rz in my tacoma, i am wanting to put new pistons, larger valves different springs, headers, intake and if i can i would even like to advance the timing a bit but in doing all this will i need to adjust factory perameters in the computer? has anyone done mods like this before?
Old Jun 9, 2010 | 06:26 PM
NwRunner's Avatar
if im not mistaken the only way to change timing on these is an adjustable cam gear from LCE
http://www.toyotacatalog.net/M1WebGe...3-57800E074F2C
Old Jun 9, 2010 | 06:49 PM
Savage1016's Avatar
well one time i scaned the obd2 system for a check engine light, i got into a menu that showed all the perameters from timing to exact temperature and rpm. now i am not sure if i could adjust them from there i was in highschool auto shop and i i just purchased the truck so i did not investigate.
Old Jun 10, 2010 | 08:41 AM
Greg_Canada's Avatar
Hey dude, no point doing all that, buy the KO racing (www.koracing.net) turbo kit and make more power at 4 psi than you will with all those mods.
there is LOTS of info on customtacos.com about boosting 2rz/3rz's... it's alot chepaer than tearing apart the whole motor.
Also, you cant flash a 3rz ECU, you need a piggyback computer (like a MAPECU2) to tune it (as well as wideband sensor, etc)
Old Jun 20, 2010 | 05:41 PM
Savage1016's Avatar
a turbo would work and i know these motors make crazy power off stock set up and 4 pounds of boost, although i am looking into desert racing and the class i would enter in is a NA class so i want to leave the boost for my next project..... a drifting taco.
kawazx636
Oct 6, 2021 03:03 PM
dbollier123
Sep 29, 2015 05:23 PM
kportercpa
Engine Swaps
Sep 10, 2015 12:08 PM
