3RZ cam and timing chain installation q's
Old Feb 24, 2014 | 09:19 AM
Utah4Runner86's Avatar
I've got a '96 3RZ motor on the stand. I pulled the cams out to replace a couple valve shims, and I've discovered I don't have the slack in the timing chain to put the intake cam back in. With my old 22RE I could lever the timing chain tensioner to make enough slack to slip the cam back on, but if that's a tensioner I can see looking down the front of the motor, it doesn't budge when I try to lever it.
My mad google skillz have failed me, is there a trick to getting the chain and cog back over the cam without pulling the timing cover? For various reasons, I'd rather not go to that extent.
Old Feb 24, 2014 | 11:09 AM
Why do you always figure it out right after you post a plaintive call for help?
The timing chain tensioner can be removed without pulling the timing cover. Look on the passenger front side of the engine for what looks like a blockoff plate - thats the tensioner. Unbolt it, pull it out, slip your cams into place, put the tensioner back. Hope this helps somebody else down the road.
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
zd92655
Jul 5, 2015 04:25 PM
