3rd gen T-case still leaking!
Old Oct 19, 2009 | 12:38 PM
xcmountain80's Avatar
Ok I pulled the necessary bits and pieces cleaned and diagnosed. Applied 1 minute gasket and re-installed. I did think it was a little wet near the top but who knows. The original gasket was hard and soaked not to mention the amount of oil moisture from the top of the t-case down.
Aaron
Old Oct 20, 2009 | 03:51 AM
Well I knew I should have waited on replacing the shifter gasket, damn I'm still leaking while not as much or at least with no skid plates it doesn't pool. Today the UV dye should be in so this is a last resort and the one I should have taken from the beginning I guess. Stay tuned for more money spent,,,,,,,,,,,, Yeah ! MY wife is right this is the money pit!
A
Old Oct 20, 2009 | 11:34 AM
Picked up the CSI leak detector... no not that kind of leak.
A
Old Oct 23, 2009 | 02:41 PM
The glow stuff worked well still left me scratching my head, it appeared to be leaking from the exact sae spot I replaced the gasket. So I pulled it only to learn there was another gasket under a razor thin plate of some kind. I used the light to determine there was fluid coming out of the shifter itself somehow. My t-case does not have a breather line I can find just a top mounted one (shown). I also pull the shifter out of the shifter housing and found DOOOM.
Anyone have a part number for this shifter bushing?
Saw the shifter seat Marlin offered but not sure which one I need!
A
Old Oct 23, 2009 | 03:10 PM
  #25
nuke1105's Avatar
so is that square paper gasket with the bolt holes in each corner the shifter gasket that everyone talks about? Because my transfercase on my taco is also leaking and im thinking it could be this gasket.
Old Oct 23, 2009 | 03:32 PM
  #26
I guess twas news to me but this is how it goes together. Shifter/ gasket/ metal plate thing/ gasket/ t-case. I also know now after searching that Marlin Crawler makes the sifter seat that was demolished on my unit. I'm not sure which I need.
http://www.marlincrawler.com/hardwar...-forward-shift
Aaron
Old Oct 24, 2009 | 08:09 AM
  #27
So I went to t5he dealer explained what I needed and they sold me p# 33505-35020. But wait it didn't fit apparently thats for the 5spd tranny shifter seat. And they only sell the entire lever with bushing for $265 ha!
A
Old Oct 24, 2009 | 12:35 PM
  #28
I returned the green non fitting shifter thing and am awaiting a white one to test fit. I missed Marlin Crawler by about 5 minutes yesterday so I will have to call 1st thing Monday, no matter which way I cut it Tuesday is the day my truck will be operational again.
A
Old Oct 26, 2009 | 06:45 AM
  #29
Just got off the phone with Marlin Crawler and overnighted the BLUE shift seat as they think it should work. A white shift seat will be in today at the Stealership so we will see how this goes.
A
Old May 5, 2010 | 08:17 AM
  #30
Qyota's Avatar
Any updates on this? Sorry for the thread resurrection.
Old May 5, 2010 | 10:27 AM
  #31
vang_22re's Avatar
Is it still leaking???
Old May 12, 2010 | 11:34 AM
  #32
BigMac's Avatar
I would like to know how this turned out since I seem to have the exact same problem.
Old May 13, 2010 | 07:42 AM
  #33
Qyota's Avatar
Mine is leaking as well, most likely from where the t-case meets the transmission. Not a likely spot, but I've pretty much ruled out the t-case shifter seal/gasket...which is just a thin piece of paper on my '99.
Not sure what else it could be, but it looks like I'm going to have to have the t-case pulled from the transmission to check the shaft bearing seal.
Old Nov 30, 2011 | 02:14 PM
  #34
Fixed!
I'm sorry I didn't wrap this up by saying yes I fixed it. It just so happens the paper gaskets were leaking and that led me to find the junk shifter seat. After 2 applications of RTV to 2 different razor type plates on top of the T-case the leak is fixed and has had to recurrence after multiple trips.
Aaron
Old Dec 15, 2011 | 09:10 PM
  #35
post office's Avatar
Is this the reason why theres oil all over underneath my truck? My oil consumption is pretty much next to nothing, but there is what looks like leaking oil underneath.
Does anyone have a picture of what leaking tcase would look like?
Old Dec 29, 2011 | 02:08 PM
  #36
Perhaps you could submit a picture of what you have and we can say yes that a t-case leak or no it isn't. ANother method if you don't have the UV kit is to use a colored oil like royal purple (purple) or amsoil (red) gear oil and see what happens. Cleaning everything with soap, simple green and water will help you determine the source.
A
Old Nov 23, 2012 | 04:19 PM
  #37
madbomber08's Avatar
So to resurrect an old thread, I have a 5 spd and have a very slow leak from where the top shifter plate mates to the transmission. So I called the dealer and they said for my VIN, they couldn't provide me with two new paper gaskets and a metal plate. So I bought some toyota transaxle fipg and planned to fipg on both the underside and topside of the thin metal plate and do away with the gaskets. Well, it looks like someone before me had already messed with it before and did away with the gaskets and thin metal plate all-together. There was just lines of old silicon that I had to peel off to clean up the surface.
My question is, should I just fipg without the metal plate in between, or should I wait and see if I can order the metal plate?
Old Nov 23, 2012 | 06:00 PM
  #38
vang_22re's Avatar
You don't need the metal plate
Old Jul 1, 2013 | 08:15 AM
  #39
ToyotaPower21's Avatar
So my Transfer case has been leaking forever and I found this tread and ended up checking my 4wd shifter and found out it had no gasket at all and was leaking around the area. I used Gasket sealant and it seems to be fixed for now! Thank god!
Old Jul 2, 2013 | 08:40 AM
  #40
stophammertime's Avatar
Agreed - I'm 99% sure this is exactly where my leak is coming from.
