3rd gen Limited fog light switch?
Old Jan 14, 2003 | 11:19 AM
midiwall's Avatar
Hi all;
Is the fog light switch for the 3rd gen's SPST, DPST, DPDT, ???
I have an idea for something that requires a DPDT switch, and I have panel space for a rocker. So I'm thinking of getting a stock switch if the mechanical makeup will fit the application.
Thanks!
Old Jan 15, 2003 | 10:41 AM
It is a SPST. Looking at the back you will see thre wires on hot, one ground (for the internal light in the switch) and one switched.
Old Jan 15, 2003 | 10:47 AM
transalper's Avatar
You'll likely have to get a cole-hersee or carling DPDT switch. I just installed a cole hersey 3-way on-off-on DPDT switch for lights and it fits perfectly. I got it here:
Cole Hersey DPDT Switch
It is not illuminated though and I'm still searching for the perfect switch.
Old Jan 15, 2003 | 01:42 PM
midiwall's Avatar
Thanks guys! I appreciate the look at the switch and the suggestion of an alternative.
I got antsy today and went with a small DPDT toggle that I can stick on the side of the console without a lot of hassle or negative impact on the interior cosmetics.
All I'm doing is selecting between two sets of horns (original and air), and I need to switch the horn trigger as well as the compressor power. I just thought it'd be "cool" to have it disguised as a normal dash switch.
Thanks again!
Mark
Old Jan 15, 2003 | 01:45 PM
I just left them both hooked up for my horns. Can't have them loud enough around here. Using the switches for driving and fog lights and an electric fan cut off for the radiator.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
Johntom240
7
Jul 13, 2015 12:18 AM
